cold starts of a few sears
15 replies to this topic
#1 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted January 03, 2016 - 05:14 PM
here is a few tractors starting in the cold
  • daytime dave, EricFromPa, davidj927 and 3 others have said thanks
#2 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted January 03, 2016 - 07:07 PM
Thanks for the vid!
  • craftsmanmowerfreak said thank you
#3 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted January 03, 2016 - 08:43 PM
your welcome :)
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 01:23 AM
Thanks I just enjoy looking at the tractors.
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 01:24 AM
Nice custom
#6 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 01:27 AM
You can fix the axle holes, what you want for the frame with the egged out holes ? I need one I'll fix it
#7 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted January 04, 2016 - 08:35 AM
i know some peoplle suggested welding washers to the frame to fix that. but got to have a good welder and not a little hobby welder lol
#8 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 08:55 AM
You can either weld them up and drill them out or weld washers to it. What kind of welder do you have its not very thick, most any welder would do it.
#9 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted January 04, 2016 - 08:58 AM
its a little lincoln with no adjustments. it takes a really long time to strike an arc. usually i end up cussing by time i get something welded lol
#10 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted January 04, 2016 - 09:04 AM
Well you can always practice on it. It doesn't have any adjustments at all no amps? Try scraping the end of your rod off before you try to strike an arc. If you already haven't done that.
#11 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted January 04, 2016 - 09:16 AM
A few questions about your welder here. Is it an arc or wire feed? Are you cleaning the area to be welded and a spot for the ground to hook to?
#12 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted January 04, 2016 - 06:10 PM
cleaned spots tried everything no adjustments at all its a stick welder
#13 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted January 04, 2016 - 06:17 PM
Hmmmm? I haven't seen a stick welder without any adjustments on it. Got a model #? Also, what rod are you using? Size?
#14 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted January 05, 2016 - 12:19 AM
http://www.lincolnel...oln3/imt681.pdf wel have tried a few size rods and i had better luck with one set but cant remember what size it was
#15 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted January 05, 2016 - 05:50 AM
That's a cute little guy! Several things to check out. How long has it been since the 'thermal protector' light on the switch has shown up? If you don't remember seeing it, the bulb may be burned out and the thermal protector is cutting in too soon keeping it from working. Are the jaws of the electrode holder clean? That could be keeping the circuit open. How do you store the rods? If they are left to draw moisture in the flux coating, they won't work well. You can take some of them and turn the oven on to a low temp. Bake them for 30 minutes or so and see if they work better.
If no improvement after that, I'd say it has reached it life cycle. There is a 15 amp fuse in there somewhere, check it too.
