First Find and Purchase of the New Year 2016
18 replies to this topic
#1 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 03, 2016 - 04:44 AM
Pretty Good looking and complete 1254.  Was a craigslist find.  Figured I better jump right on it for the $200 asking price, especially once I had the owner send me a picture of it on my phone.  Brought it home around 12 and had it running by 3!  Not much really had to be done other than drain the fuel out of the tank( luckily the shutoff was used and the carb was dry), also I needed to remove the head to deal with a stuck exhaust valve.  Other than that I borrowed a starter gen from my 900 and charged up the battery that came with it and that was it....fired right up!!  The guy that had it gave up on it a year or so ago because the starter gen stopped working for whatever reason( almost looked like it was recently rebuilt, but it almost seems like when you spin it by hand it feels a little catchy), so I will be looking into that soon.  The battery that was in it only took 10 minutes to charge right up lol, looks like it was put in around the time the starter gen stopped working.?.?  Something to check into....here are a few photos once we had it running driving and mowing......
  • Bolens 1000, rustyoldjunk, daytime dave and 17 others have said thanks
#2 KennyP ONLINE
  • 53154 Thanks
  • 53301 posts
Posted January 03, 2016 - 05:41 AM
Nice score on that, Brad!
  • Nascar3244888, boyscout862 and chieffan have said thanks
#3 boyscout862 OFFLINE
  • 15260 Thanks
  • 10023 posts
Posted January 03, 2016 - 07:19 AM
It sounds like the S/Gs brushes may be causing the "catchy" feel. The S/G may just need to be polarized. Nice GT. Good Luck, Rick
  • Nascar3244888 and chieffan have said thanks
#4 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted January 03, 2016 - 07:28 AM
You didn't waste any time getting 16 off to a good start. Nice looking tractor to start off the new year.
#5 chieffan ONLINE
  • 16593 Thanks
  • 9087 posts
Posted January 03, 2016 - 07:46 AM
You found a good one there.  Makes it easy when there is one hiding behind ever tree.  Better yet you got it running right off.  That one was not stored outside like most are.
  • Nascar3244888 said thank you
#6 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1179 Thanks
  • 697 posts
Posted January 03, 2016 - 09:27 AM
Great find and a great price as well. There is a 1050 for sale not to far from here. I may go take a look at it next weekend if I can make arrangements with the seller. It is in rough shape, but looks to be mostly there. He is asking $150 as a parts machine, but the ad also says BO, must go!, so we will see.
Jim
  • Bolens800uk said thank you
#7 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted January 03, 2016 - 09:35 AM
Great Find!!!
#8 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 03, 2016 - 10:06 AM
I would say you did well
#9 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 03, 2016 - 11:33 AM
That look like a good find and up and running within hours of owning it is a bonus.
What are you going to do with it?
#10 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 03, 2016 - 11:57 AM
Wow looks like nice original there!
Does this tractor have a modal and serial number? I can tell you what number it is off the factory line.
#11 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted January 03, 2016 - 02:14 PM
Thanks for the kind remarks everyone.  Today I took apart my first starter generator, which just so happened to be the one that came along with the 1254.  It was freshly rebuilt.  Turns out after looking it over that the armature was coming into contact with one of the field coils.  I ended up using a C-Clamp to compress the coil tighter against the inner wall of the generator.  Also Im not sure if I did it or not upon removal but the one brush spring tensioner seemed to not be sprung like the other one was.  I looked at it and it had part of the wire caught in it, so I fixed that.  After all that I cleaned the contact areas for the brushes as well as the armature and field coils, but it back together and it no longer had the catchy feeling, so I hooked it up to the jumper back and it worked!!!  I put it on the tractor and it starts and charges!! Ialso was able to clean the tractor up some, so here are some pics...
  • blackjackjakexxix, KennyP, boyscout862 and 3 others have said thanks
#12 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 03, 2016 - 02:32 PM
That come up very well. If it were me I would keep her as it is. Well done for sorting out the starter generator.
#13 KennyP ONLINE
  • 53154 Thanks
  • 53301 posts
Posted January 03, 2016 - 03:56 PM
It looks real good as is! :thumbs:  on the S/G!
#14 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted January 03, 2016 - 04:26 PM
Very nice find! She is in really nice original condition!! Keep her that way.
#15 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22752 Thanks
  • 7524 posts
Posted January 03, 2016 - 04:41 PM
Tractor looks nice!
"Turns out after looking it over that the armature was coming into contact with one of the field coils.  I ended up using a C-Clamp to compress the coil tighter against the inner wall of the generator."
If you have to take it apart again you may want to verify that the field coil shoe is ninety degrees to the end of the housing.  I replaced a field coil on the one on my 1050 several years ago and when I put it back in I did not double check the shoe and must have got it off a degree or two - worked ok when it was cold but when it got warm it did not sound quite right.  I took it back apart and could see that the armature was just touching the coil so I removed the shoe again and made sure there was nothing trapped between it and the inner housing wall and reinstalled the shoe making sure it was at a right angle to the end using a small square.  Worked good after that.
  • Paulgo and CanadianHobbyFarmer have said thanks
