Who is good identifing, a briggs ?
12 replies to this topic
#1 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 979 posts
Posted January 01, 2016 - 10:54 PM
I got a tractor someone put a briggs on. It is a 6hp horizontal shaft. Power kraft. No points has the newer ignition. Aluminum block. Has the b.s stamped into the blower cover. The cover is rusty where the model number would be so it can't be read. Of anyone has an idea of the model it would really help I'm removing it and putting the original engine back on the tractor but want to fix it to keep. I will go up to the garage and get some pics. It also has the werid older carb looks like a two piece
  • chieffan said thank you
#2 boyscout862 ONLINE
  • 10,507 Thanks
  • 7,929 posts
Posted January 01, 2016 - 11:00 PM
Download the B&S Repairmans Manual from the Manuals Section. It has a section on identifying engines. Good Luck, Rick
  • jd.rasentrac, chieffan and Tecumseh power have said thanks
#3 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 979 posts
Posted January 01, 2016 - 11:05 PM
Thanks^ here are some pics I'll look into it. Sorry they posted sideways sent from my tablet. Maybe a mod can rotate them. Thank you. Also I never do any briggs . Does anyone know the name of the carb? Two piece flo jet?
Edited by Tecumseh power, January 01, 2016 - 11:07 PM.
  • Chris11 and boyscout862 have said thanks
#4 Chris11 OFFLINE
Chris11
    old Member
  • 1,646 Thanks
  • 961 posts
Posted January 01, 2016 - 11:38 PM
I have the same engine on my panzer t 70
  • Tecumseh power said thank you
#5 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 979 posts
Posted January 01, 2016 - 11:54 PM
do you know what it is and the carb type? I'm having a hard time identifing, it. I never do any briggs . A tecumseh I could tell not this
  • Chris11 said thank you
#6 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 979 posts
Posted January 01, 2016 - 11:57 PM
I want to get a coil for it. I think they are all about the same not sure tho
#7 Chris11 OFFLINE
Chris11
    old Member
  • 1,646 Thanks
  • 961 posts
Posted January 02, 2016 - 12:01 AM
This is the model and plate off my engine, I had them redone. I know that engine was used on a snow blower called a snowbird too.BRIGGS_SPEC_PLATE__40997.1393707248.1280.1280.png
  • limebuzz and Tecumseh power have said thanks
#8 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 979 posts
Posted January 02, 2016 - 12:09 AM
Thanks is yours also a 6hp? This will help me alot. My model plate was missing, and there were no other stamps on the housing if there were it's too rusty on the sides to see.
#9 bbuckler OFFLINE
bbuckler
  • 2,367 Thanks
  • 2,140 posts
Posted January 02, 2016 - 12:18 AM
It is a two piece Flo Jet. Here is the link to the manual http://gardentractor...ines-1919-1981/
#10 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 979 posts
Posted January 02, 2016 - 12:24 AM
thank you I am going to order a new one for it. They are only 20 dollars . Needed to know the na me of it. If your interested in where they are 20 dollars see my form post I just put on titled tecumseh carburetors. Thanks again. Cheaper for me to order the carb than it is for the kits.
#11 Sprint 6 OFFLINE
Sprint 6
  • 177 Thanks
  • 230 posts
Posted January 02, 2016 - 08:48 AM
That engine most likely does have points, they would be under the flywheel.  I do agree, was likely a snow blower engine.  I would just cut a gasket for that carb, you only really need a bowl gasket, the rest can be cleaned.
#12 Chris11 OFFLINE
Chris11
    old Member
  • 1,646 Thanks
  • 961 posts
Posted January 02, 2016 - 10:51 AM
6hp or 5 3/4 hp Ive see it called that too. Yes the points are under the flywheel.
  • WNYTractorTinkerer and Tecumseh power have said thanks
#13 Tecumseh power ONLINE
Tecumseh power
  • 1,287 Thanks
  • 979 posts
Posted January 02, 2016 - 02:08 PM
Thank you guys
