cub cadet 107
electric lift
5 replies to this topic
#1 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted January 01, 2016 - 09:43 PM
I just bought a 107 with soft cab & blade  the electric lift for the blade will not lift when cold  it sometimes works when warm  the guy I bought it from said it need new brushes  any advice would be nice I have trouble with downloading pictures working on it
  • chieffan and 637Yeoman have said thanks
#2 chieffan ONLINE
  • 11,306 Thanks
  • 7,095 posts
Posted January 01, 2016 - 10:01 PM
Good chance the bushings/bearing could be bad also.  I would take it to a starter/alternator repair shop and have them look at it.  IH dealer could probably take care of it too but be more expensive.
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted January 01, 2016 - 10:17 PM
The electric lifts are great when working but rebuilding gets pricey. There are parts out there from a few suppliers and aren't so bad to go for yourself! Good luck.
  • Alc and chieffan have said thanks
#4 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted January 02, 2016 - 01:01 AM
Pull the motor off the e-lift and take it apart and look it over good for worn parts. I took mine into an electrical shop, Positive Electric, they did some type of bench test, ground the commentator and installed new brushes... Don't recall the price, but it wasn't like an arm or a leg, nothing that bad... :thumbs:
Thing worked perfectly after.
  • Alc, BNK and chieffan have said thanks
#5 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted January 02, 2016 - 12:43 PM
I do plan to take drive end apart to check bearings and lube up the manual helped!!
  • BNK said thank you
#6 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted January 03, 2016 - 03:40 AM
i had a thought after seeing parts schematic maybe the gear box part has too heavy grease. so when it is cold it does not work well I guess i will find out when i get it a part
Also tagged with one or more of these keywords: electric lift
