Bolens 850 Seat Cover Project
52 replies to this topic
#16 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted January 03, 2016 - 10:15 PM
refresh my memory the 900 seat has the material crimped under the outer metal lip of the seat pan does it not?
I believe so, I'll try and get a pic for you of what's left of mine.
#17 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22746 Thanks
  • 7519 posts
Posted January 04, 2016 - 03:16 PM
Got the lower edge sewed and fished the pull rope around the outside edge.  Then I removed the old padding which was glued to the original cover - it is a little thin in spots so I will have to get some new padding material when I get time.  Did a test fit of the new cover and it appears to fit fairly well - here are pictures of the original and the new cover for comparison.
I have started an "in depth" post of the steps involved in making this cover in hopes it will help some other members in the Tractor Restoration Tips And Tricks section http://gardentractor...a-lawn-tractor/  if anyone is interested.
  • Alc, Bruce Dorsi, ClassicBolens and 1 other said thanks
#18 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 04, 2016 - 05:20 PM
Very nice Stew
  • 29 Chev said thank you
#19 Bolens 1000 ONLINE
  • 17552 Thanks
  • 18863 posts
Posted January 04, 2016 - 05:40 PM
have you found any sources to include the padding with your cushions?
#20 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22746 Thanks
  • 7519 posts
Posted January 04, 2016 - 05:50 PM
I have talked to a couple of suppliers but I have not made it to their show room to verify the firmness of the padding they offer - both are a two hour drive from me and in the "Big City".  I don't get out much this time of year as the weather can be unpredictable but hope to visit them sometime this month and see what they offer - it is hard to feel the firmness of padding by looking at them on a computer screen.
:D
  • Bolens 1000 said thank you
#21 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted January 04, 2016 - 06:23 PM
Looks great Stew!
#22 rumbleseat OFFLINE
rumbleseat
  • 130 Thanks
  • 83 posts
Posted January 05, 2016 - 11:18 PM
Awesome.
#23 jpackard56 OFFLINE
jpackard56
  • 1838 Thanks
  • 1434 posts
Posted January 06, 2016 - 11:44 AM
Very Nice :thumbs:
#24 devans OFFLINE
devans
  • 371 Thanks
  • 257 posts
Posted January 06, 2016 - 01:43 PM
:D
See if they will ship you some samples of the foam you're interested in. The samples could be simply scrap pieces that was headed to the garbage.
Great work BTW and thanks for the how to thread.
#25 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22746 Thanks
  • 7519 posts
Posted January 15, 2016 - 04:43 PM
Been stormy and cold here earlier this week so I have been in snow removal - stay warm in house mode but today I got a bit of time to start cleaning up the seat pan.  First thing I did was take some pictures with sizes of various sections of the seat pan as this may help someone identify as to whether they have the correct seat pan for an 850.
  • blackjackjakexxix and WrenchinOnIt have said thanks
#26 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22746 Thanks
  • 7519 posts
Posted January 15, 2016 - 04:44 PM
Then I sanded the seat pan, cleaned up a few rust areas and gave it a coat of paint.
#27 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22746 Thanks
  • 7519 posts
Posted January 15, 2016 - 05:03 PM
While the seat pan was drying I decided to try an experiment.  I had some 2-1/2" thick foam that my dad purchased a long time ago and has been rolled up for about 20 years.  It was about 18" wide X 48" long and I unrolled it and let it sit for a few days occasionally rolling it up the opposite way than it had been rolled to get it to lay reasonably flat.  Since the foam for the 850 seat pan is 1-1/2" thick I was trying to think of a way to rip the 2-1/2" thick foam piece to make it thinner so I decided to take a two 2X4 and lay one on each side of the foam to give me a 1-1/2" edge on both sides as a reference.  Then I took a piece of 1/2" plywood about 8" x 12" to use as a way of holding the foam flat on the work table with one hand (I wanted a large surface area contact so that I did not compress the foam while I was holding it) and a regular hand saw and starting at one end ripped the foam length wise by slowly drawing the hand saw towards me on an angle while it lay against the 2X4's to maintain the correct thickness.  Once I had drawn the saw towards me I would stop and reposition it away from me and draw it towards me again and it would rip the foam a bit more.  I continued to do this until I had the foam chunk ripped.  Unfortunately I did not take many pictures while I was doing it but hopefully these will give you an idea of how I did it.  I will have to take the grinder to the surface of the foam to smooth it up a little bit but I think it turned out pretty good in my opinion.
Edited by 29 Chev, January 15, 2016 - 06:54 PM.
  • Bolens 1000, blackjackjakexxix, Chubien and 1 other said thanks
#28 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 15, 2016 - 07:19 PM
Your always coming up with a way to try and make things work
#29 Chubien OFFLINE
Chubien
  • 648 Thanks
  • 399 posts
Posted January 15, 2016 - 07:29 PM
I guess the replacement cushions could be a little thicker than the original?
Looking good
#30 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22746 Thanks
  • 7519 posts
Posted January 16, 2016 - 07:06 PM
Thanks for the kind words - the foam could be thicker but I am trying to stay with 1-1/2" thick foam for your seat as that is what it was originally.
Got the door edge moulding installed around the outer lip of the seat.
