iSavetractors carburetor
4 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,965 Thanks
  • 9,612 posts
Posted January 01, 2016 - 04:09 PM
Has anyone had experience with the iST carbs advertised on our site? Are they a copy of a Carter/Kohler carb or a Walbro wannabe?
  • 637Yeoman said thank you
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted January 01, 2016 - 05:20 PM
you lost me! Got a link?
#3 bbuckler ONLINE
bbuckler
  • 3,306 Thanks
  • 2,971 posts
Posted January 01, 2016 - 05:28 PM
http://isavetractors...d-k301-engines/ and http://isavetractors...m-twin-kt-twin/
Edited by bbuckler, January 01, 2016 - 05:29 PM.
#4 bbuckler ONLINE
bbuckler
  • 3,306 Thanks
  • 2,971 posts
Posted January 01, 2016 - 05:31 PM
From the site
PRODUCT DESCRIPTION
This carburetor replaces the Kohler/Carter Number 26 Carburetor.
  • It has a 26mm/1.07" Diameter Throttle Bore.
Will fit all Kohler K241 and K301 Engines with Newer Style Choke Linkages.
How Do you know if Your Engine Uses the New Style Choke Linkage?
See the photo in the product photo gallery. Your engine will have a choke bracket on the blower housing
This carburetor will also fit the following engines:
  • K241, K301 - Direct Replacement
  • KT17*, KT17II*, KT19*, KT19II*, MV16*, M18*, MV18*, M20* MV20*, K482* AND K532* - will work with modification
* Throttle Bore and Venturi Size match original but the throttle lever will need to be modified to accommodate air cleaner and governor arm set up. Please contact us for details.
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,965 Thanks
  • 9,612 posts
Posted January 01, 2016 - 07:44 PM
Yes, it replaces the Carter, but so does a Walbro.
