Ariens fuel tank needed
9 replies to this topic
#1 K2KR OFFLINE
K2KR
  • 6 Thanks
  • 12 posts
Posted January 01, 2016 - 12:05 PM
I need an Ariens fuel tank 03507100 for a YT1132 . It's a molded plastic one that is apparently "not available" new anymore. A guy on Ebay had one but it got sold. econvert.jpg
Thanks,
KR, California
#2 boyscout862 OFFLINE
  • 13,545 Thanks
  • 9,425 posts
Posted January 01, 2016 - 12:21 PM
I may have an Ariens RER in my junk tractor area. That number doesn't mean anything to me. Post a pic. Good Luck, Rick
Edited by boyscout862, January 01, 2016 - 12:23 PM.
#3 Bolens 1000 ONLINE
  • 15,402 Thanks
  • 18,277 posts
Posted January 01, 2016 - 01:57 PM
Thats still shows as a valid part number retail is around $100 new, can be bought any any ariens dealer
  • boyscout862 and chieffan have said thanks
#4 K2KR OFFLINE
K2KR
  • 6 Thanks
  • 12 posts
Posted January 04, 2016 - 01:27 PM
Here is a photo
photo Of Ariens YT11 fuel tank 03507100
#5 K2KR OFFLINE
K2KR
  • 6 Thanks
  • 12 posts
Posted January 04, 2016 - 03:08 PM
I do see that the Gravely Parts seller Richards Lawn and Garden lists a new one for $99, but all the Ariens dealers I saw stated that the item was unavailable--which is interesting. If boyscout862 has a good used one I would buy used.
Thanks,
KR
#6 Billy M OFFLINE
Billy M
  • 729 Thanks
  • 571 posts
Posted January 05, 2016 - 12:53 PM
Is it leaking at the seam?  Is it cracked?  Is repairing an option?  I've had luck with some "plastic welding" products.  I've even used a head gun and pieces of the same type of plastic and welded/fused pieces together.  It wasn't pretty, but worked.
I'm assuming you have a tank to start with.  =)
Edited by Billy M, January 05, 2016 - 12:54 PM.
  • K2KR said thank you
#7 K2KR OFFLINE
K2KR
  • 6 Thanks
  • 12 posts
Posted January 09, 2016 - 04:30 PM
quite a few cracks--what plastic welding product might work?
#8 Billy M OFFLINE
Billy M
  • 729 Thanks
  • 571 posts
Posted January 11, 2016 - 09:27 AM
I would probably look at a replacement if you have a few cracks.  I'll personally fix one leak/crack in a fuel tank.  More than that will justify a replacement to me.  You don't want to chance too much fuel leaking out, especially in an engine compartment.  That gets dangerous real quick!  It looks like your tank is at the back of the machine.  You'll just be leaving a trail of dead grass behind you! =)
As far as plastic welding...if you try it, make sure you clean the tank out very well.  You will be working with heat on a fuel containment vessel!  Look at the plastic welding equipment HF sells.  I've only used it a couple times on small cracks, so I can report how well it would work on anything of a decent size.  I probably wouldn't recommend it in your case.  Also, you would be spending a decent amount of coin on tools/rods that you could buy a replacement tank with, granted you can find one.
http://www.harborfre...?q=plastic weld
Good luck!
Billy
#9 K2KR OFFLINE
K2KR
  • 6 Thanks
  • 12 posts
Posted January 28, 2016 - 03:13 PM
Jacks Small Engine took my order but then said the part was unavailable and cancelled my order. So I put an order in with RichardsLawn Gravely dealer. Hopefully they will come through.
#10 K2KR OFFLINE
K2KR
  • 6 Thanks
  • 12 posts
Posted January 28, 2016 - 05:07 PM
Richardslawn Gravely also says unavailable.
So I do need a used one if anybody knows of one.
