::welcometogttalk:
It's important to know what you have. The Gear drive and Hydro drive are very different critters in many ways and the tinwork back there is not interchangeable.
Btw, I moved your post out in the open so it wasn't buried in an older thread. I also removed your email as posting them in the open forum is a great way to get a bunch of spambots contacting you.
Hope you find what you're looking for.
Not sure. New to these. Let me do some research. I would upload pictures but I don't know a URL from a DVD. This tractor has variable speed handle on right and the shifter under the seat. Is there anything that distinguished the two types of tractors?
Have not had time to get to the warehouse, but the old massey brochure shows the hydra with a decal (which could be missing) and a large hydro-shifter on the right hand side where I have a vari-drive handle and no additional shifter. Am I correct in assuming that this is a gear drive?
I understand now. Going back to my original question. I'm going to need some sweetmeat (from the foot supports up) if anyone out there has a parts tractor somewhere.
NEW QUESTION: I would like to put duals on my MF 12 with bar tires and rib-looking tires on the front. Does anybody make the spacers or do I need to do that? I see pictures of MF-12's with this tractor tire setup. Could someone please let me know which direction to go for sources to do this. I think I can get the rear tires out o TSC.
If you go to agcoparts.com, select guest, select Massey, select 12
You should be able to see exploded views.
Referencing parts may help someone help you.
Also, the tires can be had much cheaper for about the same quality from greater cleveland tire
Of course, doing duals wont gain you much traction and is a little harder on the rear end, but I understand the need for the look
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
