wide area mowers
13 replies to this topic
#1 dryrun OFFLINE
dryrun
  • 56 Thanks
  • 342 posts
Posted April 23, 2011 - 05:43 PM
Has anyone on here ever used a large pull behind widearea mower such as golf courses use? Rotary type, either pto or hydraulic drive. If so, would like to hear about it or see pics.
Best regards, George
#2 mjay OFFLINE
mjay
  • 6 Thanks
  • 65 posts
Posted April 24, 2011 - 01:35 AM
Used the self powered WAMs, both rotary and reel. Think 16' was the largest. Never a tow behind though.
Watching the thread with interest as I am thinking of getting a batwing roller mower around the 10-12' mark.
Doing this with a 6' mower and its taking way too long (11 hours)
Edited by mjay, April 24, 2011 - 02:09 AM.
#3 dryrun OFFLINE
dryrun
  • 56 Thanks
  • 342 posts
Posted April 24, 2011 - 05:02 PM
I hear you about the time MJAY, I mow about 80 acres every week. We use a Woods 16 foot folding batwing bush hog type mower. we try to keep all this fescue about 4 to 6 inches high. Estate owner likes it at this height. We are currently trying to dial in a Toro parkmaster. It is a 7 unit reel machine, but has issues climbing hills, mows really good though. we are not giving up on it, but cannot make real good time mowing. Bat wing will mow/chop acre about every 5 min if you hammer down, but the big hill and a case farm tractor pulling it the "pucker factor" is pretty tremendous. And, although the owner is ok with the job it does, I don't care much for the finished look. Owner is looking for a used Toro Groundsmaster to purchase. pm_gas (Small).jpg
#4 matts OFFLINE
matts
  • 48 Thanks
  • 166 posts
Posted April 25, 2011 - 10:25 PM
We use a JD 365 reel unit. Its a batwing style pull behind. Its a pto powered hydro pump on the unit that drives the reels. The lift is operated by a remote on the tractor. I also have fairway units that cover alot of ground. We mow 158 acres every week at the golf course. The boss wants rotary mowers, but for a clean fast cut its hard to be a hydro reel.
  • dryrun said thank you
#5 matts OFFLINE
matts
  • 48 Thanks
  • 166 posts
Posted April 27, 2011 - 09:34 PM
Heres the pics of my 365
#6 dryrun OFFLINE
dryrun
  • 56 Thanks
  • 342 posts
Posted April 28, 2011 - 06:43 PM
Matts, thanks for post here, and emailpics. that gives me a good idea of what I'm looking for.
regards, george
#7 dryrun OFFLINE
dryrun
  • 56 Thanks
  • 342 posts
Posted April 29, 2011 - 06:38 AM
Local AG dealer referred me to REYNOLDS JOHN DEERE in FISHERS INDIANA, they are a Golf and Turf dealer. Salesman knew what I was talking about and will be faxing brochures.
Matts, thanks again for your pics, and info really glad to get and to hear from you. Whatever we decide to do, might try to lean on you again.
Best regards, george
#8 mjay OFFLINE
mjay
  • 6 Thanks
  • 65 posts
Posted April 29, 2011 - 03:53 PM
I'm surprised you get a decent cut with a reel cutting at 4-6"?
Rotary is cheaper to run in terms of maintenance.
I prefer direct drive units over hydraulic drive as it consumes less power (less diesel).
I see you can get multi gang flail units now.
#9 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted May 01, 2011 - 02:52 PM
I have been an Equipment Manager for golf courses for the past 18 years and have had pull behind rotary and reel units and self propelled rotary mowers. I much prefer the self propelled mowers because there is only one machine to service and they fit on the equipment lift for servicing while the pull behinds require crawling around on the ground to service them. The larger self propelled units can cost up to $65K new and even the used ones will run over $30K.
Toro, Jacobsen, and John Deere are the big three in the golf industry and all make decent machines and there are also some other players such as Howard Price and Kubota. Lastec makes a model 721X tow behind with 7 PTO powered 21" decks with a 120" cut path that sell for about $20K that will cut up to 5" high and is very user and maintenance friendly
#10 matts OFFLINE
matts
  • 48 Thanks
  • 166 posts
Posted May 01, 2011 - 06:37 PM
While I agree somewhat, I made my recomendation on the fact that most estates do not have a golf lift. And they probably have a tractor wich will save thousands over a self powered unit. The Deere units reels will pull up vertical for service. This means never crawling under it. I have 4 JD WAMs. The 365 is still the fastest and cheapest to operate.
#11 chris597 OFFLINE
chris597
  • 1 Thanks
  • 16 posts
Posted May 04, 2011 - 10:38 PM
Swisher makes a few models.
#12 poncho62 ONLINE
poncho62
  • 1,603 Thanks
  • 1,612 posts
Posted May 05, 2011 - 06:21 AM
84 inches wide enough?
#13 matts OFFLINE
matts
  • 48 Thanks
  • 166 posts
Posted May 10, 2011 - 06:52 PM
Is that a national? I just inherited one of those. Mine is a newer model with a full body. They are meant as rough cut units. Mine will hold on a 50 degree angle
#14 poncho62 ONLINE
poncho62
  • 1,603 Thanks
  • 1,612 posts
Posted May 10, 2011 - 06:58 PM
Mid 70s I believe......my dad had one when I was a kid.....so I found one .
