Sunstrand 15 Neutral?
9 replies to this topic
#1 Paulgo OFFLINE
Paulgo
  • 663 Thanks
  • 438 posts
Posted December 31, 2015 - 12:43 PM
One of my Bolens QT16's, with an inline Sunstrand 15, won't sit still. I have adjusted the neutral position in and out several times. Everything feels normal, but I can't trust the tractor to stay put and have to shut it down any time I leave the seat. Thoughts?
Thanks, Paul
  • 637Yeoman said thank you
#2 olcowhand OFFLINE
  • 38,034 Thanks
  • 30,448 posts
Posted December 31, 2015 - 12:45 PM
More than likely you have wear in linkages causing this.  If so, the only way to stop the creeping is to renew all the linkage points to remove all free play.
  • limebuzz, KennyP, TomLGT195 and 2 others have said thanks
#3 limebuzz OFFLINE
limebuzz
  • 949 Thanks
  • 936 posts
Posted December 31, 2015 - 01:05 PM
Or just park it up against your she'd. Lol. Just kidding. I second olcowhand
  • KennyP and Paulgo have said thanks
#4 chieffan OFFLINE
  • 8,381 Thanks
  • 5,799 posts
Posted December 31, 2015 - 01:18 PM
Had a severe linkage problem with the clutch in a Bolens 850.  Yoke end was wore clean through the bracket as was the bushing.  Hole was enlarged on the bracket on the clutch pedal as well.  Welding shop welded both holes shut and re drilled them, made a new bushing and it is like new again.
Weld is harder than the original material.  You may have to do the same thing.
  • Paulgo said thank you
#5 glgrumpy OFFLINE
  • 8,105 Thanks
  • 7,546 posts
Posted December 31, 2015 - 02:02 PM
Aren't All hydro tractors "Creepy" :smilewink:
  • Paulgo and Marty'70 have said thanks
#6 KennyP OFFLINE
  • 34,210 Thanks
  • 43,326 posts
Posted December 31, 2015 - 02:17 PM
Not if adjusted right!
#7 Paulgo OFFLINE
Paulgo
  • 663 Thanks
  • 438 posts
Posted December 31, 2015 - 03:04 PM
I have 3 others that are the same setup. They stay where I tell them to. This one has an attitude. Will study the linkage more and see if I can find some slop or wear. Thanks!
#8 KennyP OFFLINE
  • 34,210 Thanks
  • 43,326 posts
Posted December 31, 2015 - 03:21 PM
Gonna have to let it know who's the boss!
  • limebuzz and Paulgo have said thanks
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,191 Thanks
  • 5,786 posts
Posted December 31, 2015 - 03:48 PM
Whip it! Whip it GOOD!!!
  • limebuzz, KennyP and Paulgo have said thanks
#10 glgrumpy OFFLINE
  • 8,105 Thanks
  • 7,546 posts
Posted December 31, 2015 - 06:57 PM
Maybe instead of Slop, is just too rusty tight on linkages?  Might try lubing, oil, grease or ? to free up more. I've even had some brands Like MTD's just full of grass and junk around that area and was blocked. Once freed up it may shake down to the N spot it wore in the linkage long ago! :smilewink:
