snow blower question
11 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 30, 2015 - 11:28 PM
I have a 214 with a 37A blower. Do I have to have wheel weights or will it be ok without them?
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,142 posts
Posted December 30, 2015 - 11:32 PM
I ran my 212 with WWF loaded tires and a wooden box that weighed 50 pounds on the hitch, with chains, and never got stuck in three years.
  • chieffan said thank you
#3 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 30, 2015 - 11:45 PM
So what's loaded tires?
#4 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted December 30, 2015 - 11:51 PM
any thing inside the rear tire besides air.
WWF - is windshield washer fiuld
some have made box to fit on the rear hitch and load it with sand, metal or cement, etc.
I have use a short piece of railroad rail, until I found an old elevator counter weight ( 100 lbs) got two of them
  • chieffan and coinman66 have said thanks
#5 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted December 31, 2015 - 12:06 AM
You can make your own wheel weight.
I have make a set of concrete wheel weight.
to make a set of concrete weights you nee to remove one of the rear tires.
cut some cardboard - one piece to go around inside the rim and another piece to fit over the lug bolt holes.
then put garage bag in the wheel  covering the cardboard.
then you will need two or four pieces of 1/2 pipe ( I used copper pipe) cut to length that you want.
then bolt the pipe to the wheels - there should be four square holes in your rims.
then mix up some ready mix and pore in the garage bag.
you can make them as thick as you want - best would be 4" to 6" thick.
they will last for many years.  Mine are 20 years old and I still use them.
  • coinman66 said thank you
#6 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted December 31, 2015 - 12:27 AM
You may get along with just tire chains in Illinois, not much snow. Just don't make as big of cuts while blowing powder.
#7 dodge trucker ONLINE
dodge trucker
  • 2,825 Thanks
  • 3,459 posts
Posted December 31, 2015 - 06:51 AM
When I had my 2 SS12's with the snowblowers, I had chains on both and weighs on one of them, the one w/o any weight in the back tires was almost worthless
  • propane1 and chieffan have said thanks
#8 chieffan ONLINE
  • 11,379 Thanks
  • 7,121 posts
Posted December 31, 2015 - 07:44 AM
I have the G12 with the thrower on, loaded tires and chains.  As long as I keep the diff lock screwed in it goes where ever reasonable with no problems.  The H16 with a front blade has JD wheels and tires so no room for chains, just weights.  Haven't used it yet.  G16 has chains only and used as a yard donkey and get along good pulling a yard wagon full of wood.
#9 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 31, 2015 - 08:13 AM
The tribe has spoken. Thanks guys!
#10 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 31, 2015 - 01:05 PM
Here are some before and after pics. Rattle can paint job. Like to thank Lyall (Glen) for all his help .
Edited by coinman66, December 31, 2015 - 01:06 PM.
  • lyall said thank you
#11 Leonard VanCamp ONLINE
Leonard VanCamp
  • 658 Thanks
  • 474 posts
Posted December 31, 2015 - 03:35 PM
I have 316K with a 49 blower on it. Last year I ran just ag tires and 220 lbs of wheel weights, it did alright in the snow but spun on the ice so this year I added tire chains.
#12 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted December 31, 2015 - 05:58 PM
that snowblower is looking good.  should be able to use it soon.
glad to help you
