coil conversions on Briggs & Stratton
6 replies to this topic
#1 thom OFFLINE
thom
  • 323 Thanks
  • 239 posts
Posted December 29, 2015 - 03:35 PM
This may have been dealt with on here before, but ... I think some Briggs engines CAN NOT  be converted to pointless ignition by simply bolting on a "late model" coil, and I know that some can. Which ones won't work? How do I know , other than bolting one on and trying it? The magnet or magnets in the flywheel must be different? THANKS.
  • chieffan said thank you
#2 Bolens 1000 ONLINE
  • 12,934 Thanks
  • 17,302 posts
Posted December 29, 2015 - 03:38 PM
Correct, Some coils will accept the new conversions but some will not, If you have a model of what one your thinking I may be able to tell you by searching the coil part number in my system.
Of course I do suggest keeping OEM points and condensers but I am a stickler for original parts and old technologies :D
  • boyscout862 and chieffan have said thanks
#3 thom OFFLINE
thom
  • 323 Thanks
  • 239 posts
Posted December 29, 2015 - 04:13 PM
Thanks. The engine is on my Bolens G-9. The engine #s are - model 190417, type 0902-01, serial 76011410. I tried a "known good" coil off of a newer engine and get no spark.
#4 Bolens 1000 ONLINE
  • 12,934 Thanks
  • 17,302 posts
Posted December 29, 2015 - 04:21 PM
The coil for that is the B&S 298968 and I believe the Nova modules can be used on them but have never tried it, I dont see any notes not saying the modules cannot be used in my cross references.
Have you cleaned the points on this engine before swapping coils? Most of the time a cleaning and possibly replacement of the points and condenser is all that is needed to get spark again. Also sometimes the little plungers get stuck/worn not allowing the points to open all the way.
#5 thom OFFLINE
thom
  • 323 Thanks
  • 239 posts
Posted December 29, 2015 - 04:59 PM
Actually , the points didn't look good. I cleaned them and the engine ran for a few seconds and lost spark again . Cleaning again produced the same results. A few seconds running again then no spark. Then I tried the pointless coil. No spark at all. Today, I bought a set of points and will swap back to the original coil and install the new points tonight.
#6 Bolens 1000 ONLINE
  • 12,934 Thanks
  • 17,302 posts
Posted December 29, 2015 - 05:02 PM
make sure you replace the condenser as well (They should come in the kit)
#7 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,362 Thanks
  • 2,209 posts
Posted December 29, 2015 - 05:11 PM
A few possibilities:
Is the point adjustment slipping, allowing the points to stay closed all the time?
Do the points need to be re-gapped each time?  .......Rust on the crankshaft (under the oil seal) may be wearing the plunger, affecting point gap.
Is oil getting past the seal and coating the point contacts?
  • Bolens 1000 and Alc have said thanks
