26/12/12 tires
3 replies to this topic
#1 Rbrracing32 OFFLINE
Rbrracing32
  • 16 Thanks
  • 56 posts
Posted December 29, 2015 - 01:34 AM
May be dumb question but have I got raise my fenders to put 26 cepecks on a 106.
#2 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 871 Thanks
  • 722 posts
Posted December 29, 2015 - 08:35 AM
Most likely. There's not much room with 23/10.50 12 so the extra height will rub.
#3 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted December 30, 2015 - 12:06 AM
23 .10.50 you shouldnt have to raise but with the 26 youll have to. You should have to raise about 2 inches or so. Its not a very big increase in height.
#4 WIGTPuller OFFLINE
WIGTPuller
  • 8 Thanks
  • 12 posts
Posted December 30, 2015 - 06:18 PM
If you have the late generation Cepek giant pullers you will have to raise the fenders.  If you have the first generation giant pullers that closely resemble the Firestones everyone seems to like, you can leave the fenders alone.  HOWEVER, though there will be clearance, there won't be much.  I have a set of first generation Giant Pullers on my 14 stock puller that started life as a 104 chassis.
Another way to cheat the fender clearance is move the rearend back.  That is IF your club rules allow it.  It's easy to raise the 106 fenders with some 1" square stock, slipped in under the battery compartment.
Best of luck!
