Needed Heat this evening and the heater would not start
8 replies to this topic
#1 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted December 28, 2015 - 08:18 PM
:mad2:  Went from 80's to 30's here, been using the electric heater to run the chill out in the evenings. I needed the propane tonight. Only the pilot would come on, would shut off as soon as I tried to turn a burner on. I disassembled it to see why. I found the tip-over switch and disconnected it and shook the ball around inside it. I re-installed it and re assembled. Fired right up! Yaaaa Heat is back in Texas!
  • Alc and propane1 have said thanks
#2 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,548 Thanks
  • 6,199 posts
Posted December 28, 2015 - 08:27 PM
I always find it funny that safety switches are almost always the culprit with an unexplained "stopped working"
Glad you got some heat!!
  • karel and propane1 have said thanks
#3 Jazz ONLINE
Jazz
  • 2,605 Thanks
  • 1,526 posts
Posted December 28, 2015 - 08:37 PM
I have found with propane it has been the safety sensor on the can most times  is culprit when I can't get bbq to light. The sensor at  KNOB is just too SENSITIVE.. usually unscrew connection at bbq,,reconnect and it works...
This is very frequent problem I have experienced...I took one tank back and told them I could not get fuel..BIL filled me in on the problem,,,the safety on your heating unit may not be the problem.
BTY its 10F here...my fires on...
Edited by Jazz, December 28, 2015 - 08:39 PM.
  • propane1 said thank you
#4 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted December 28, 2015 - 09:30 PM
This thing has a sensitive tip over switch. Just bumping it will shut it down. Good thing I think. I guess the ball inside the switch may have lost contact, and my shaking it seems to have fixed it. I needed something to work on anyhow.
#5 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 870 Thanks
  • 722 posts
Posted December 28, 2015 - 09:52 PM
Part of the welcome speech at Ft. Hood was "Welcome to Texas, if you don't like the weather just wait a few hours it will change." Hahahahaha. I swear I have seen all 4 seasons in one day down there!(on several occasions)
#6 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted December 28, 2015 - 10:40 PM
Yep.
#7 glgrumpy ONLINE
  • 8,746 Thanks
  • 7,983 posts
Posted December 29, 2015 - 12:07 AM
Hope we're talking in shop here? Can't be house without furnace?
#8 chieffan OFFLINE
  • 10,962 Thanks
  • 6,946 posts
Posted December 29, 2015 - 08:04 AM
Been down in the upper teen's here at night and up to upper 20's during the day.  Multi-fuel stove in the basement keep it comfortable most of the time when we are moving & working around the house.  Early morning and again 6 the furnace kicks on.  Use the wood fireplace for a short while in the am and again round 3 till bed time. Sure saves on the propane.
#9 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted December 29, 2015 - 08:46 AM
Yes glgrumpy, I am talking about the Shop heater. So far it is still working good, Was in the low 30's last night, and I was comfortable at 68* and was only running it on the medium setting.
