Sears 1967 super 12 Electrical help
ignition
28 replies to this topic
#1 bduce77 OFFLINE
bduce77
  • 13 Thanks
  • 23 posts
Posted December 27, 2015 - 05:56 PM
just picked up a 67 super 12    I need to redo all of the wiring. does anyone have some type of electrical scmatic for it
Thanks ~Ben
  • boyscout862 and chieffan have said thanks
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 27, 2015 - 06:01 PM
Welcome to GTTalk!  Have you checked the manuals section yet? If not, check here for a manual
  • boyscout862, chieffan and bduce77 have said thanks
#3 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted December 27, 2015 - 06:04 PM
:wave: Welcome to the forum! On page 8 of this manual is a wiring diagram.
#4 bduce77 OFFLINE
bduce77
  • 13 Thanks
  • 23 posts
Posted December 27, 2015 - 07:10 PM
Thank you
  • chieffan said thank you
#5 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,175 posts
Posted December 27, 2015 - 08:34 PM
Welcome to GTT. As you can see we have a nice bunch of tractorholics here. Good Luck, Rick
  • chieffan and bduce77 have said thanks
#6 bduce77 OFFLINE
bduce77
  • 13 Thanks
  • 23 posts
Posted December 27, 2015 - 09:09 PM
Thanks- just started getting into vintage tractors and already own two. It is very cool how nice and helpful every one is on forums and Facebook groups.
Edited by bduce77, December 27, 2015 - 09:11 PM.
#7 MH81 OFFLINE
Posted December 28, 2015 - 07:28 AM
I know that there is an uploaded manual that is scans of most of the different wiring
Think the members name was Murdock?
Anyways, :welcome: To GTTALK
#8 MH81 OFFLINE
Posted December 28, 2015 - 07:30 AM
, here it is http://gardentractor...iring-diagrams/
#9 bduce77 OFFLINE
bduce77
  • 13 Thanks
  • 23 posts
Posted December 28, 2015 - 09:11 AM
Thanks. I have to wait a day. Said I can't download because I exceeded my daily amount
#10 John Arsenault ONLINE
John Arsenault
  • 2,600 Thanks
  • 1,217 posts
Posted December 28, 2015 - 09:15 AM
If you find you have a no spark issue, I just got a kit for my sears from overnight solutions and it was easy to install. I like it so much I am going to buying another one for my other sears. I found that with the overnight solution ignition kit that re-wiring the whole thing was going to be my best bet because I did not want to add a second toggle to put power to the coil. So I got a new ignition switch and a starter solenoid to by pass that. I just did a hand written schematic but its pretty much the same as they use in the older Simplicitys with the briggs cast iron engines. This one is a little different because the ignition switch is no longer grounded to the kill circuit , instead the ignition just cuts off power to the coil.
  • 6mikey7 and bduce77 have said thanks
#11 MH81 OFFLINE
Posted December 28, 2015 - 12:22 PM
This does bring up an interesting point, If you miswire it... Bad things can happen. The cheaper fixes are north of $100, so be careful
#12 bduce77 OFFLINE
bduce77
  • 13 Thanks
  • 23 posts
Posted December 28, 2015 - 06:08 PM
I ended up ordering a new ignition that replaces mine from Milfordpower.com    Im going to play it safe and replace all of the wires to insure they have a good conection and are clean
#13 MH81 OFFLINE
Posted December 28, 2015 - 08:37 PM
There are lots of incorrect info out there. Do you have a link to the padt they say will work anddo you have a picture of the part you need toreplace?
There are other things that will cause no spark also. Its best usually to methodically test thru them.
Do a site search for tickle test and you will find many threads onthe issue.
#14 bduce77 OFFLINE
bduce77
  • 13 Thanks
  • 23 posts
Posted December 28, 2015 - 09:45 PM
It's not a spark issue. More of a old and dirty bad wires, not allowing power to get to starter. I hope lol
I'm also replacing the old brittle wires at the same time
Edited by bduce77, December 28, 2015 - 10:04 PM.
#15 bduce77 OFFLINE
bduce77
  • 13 Thanks
  • 23 posts
Posted December 28, 2015 - 10:01 PM
This is what I purchased
Also tagged with one or more of these keywords: ignition
