I bought a set of 9 bulb LED spot light on ebay for about $24 shipped. The housing had an "eyebrow" on the top which I ended up cutting off with grinder. I also had to groove 2 spots as housing was a tad larger than my mounting pad. Once fitted, I made up a couple hillbilly hold down tabs and screwed them tight. I would like to redo them, if anyone has any better ideas let me know.
I hooked up the wiring and bam, there you go. The factory nose mounts must angle the original bulbs down as the beams seem to be angled to the ground, but I am overall happy with them. I'm not going through the woods at 50 mph so I think the will be fine. They only draw about 2-3 amps.
First dark pic is at about 10 feet, other dark pic is about 22-25 feet.
CAN MODERATOR ROTATE 2,3 and last 2 PICS? Stupid phone!
Edited by MH81, December 27, 2015 - 08:20 AM.
