Kohler K341 at 2200 rpms
8 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,421 Thanks
  • 3,043 posts
Posted December 24, 2015 - 04:02 PM
Brand new carb and can't get it adjusted below 2200 rpms and new intake gasket.
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted December 24, 2015 - 04:19 PM
What kind of carb Walbro or Carter?
#3 bbuckler ONLINE
bbuckler
  • 3,421 Thanks
  • 3,043 posts
Posted December 24, 2015 - 04:23 PM
Walbro. With idle screw all the way in it still is 1900 rpms.
Edited by bbuckler, December 24, 2015 - 04:24 PM.
#4 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted December 24, 2015 - 04:27 PM
I never had any luck with the Walbro I have on my K341, tried everything I could but could not get it to run right. As soon as I changed rpm or load on the motor it would act up.
I put a Carter #30 on it and after a couple of small adjustments it runs good, high and low rpms, different loads, it run the way it should.
Why ??? I don't know.
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted December 24, 2015 - 04:36 PM
Make sure the butterfly is installed the right way there should be an indentation on it that needs to be at 12 o'clock
  • limebuzz, boyscout862 and Oldford have said thanks
#6 bbuckler ONLINE
bbuckler
  • 3,421 Thanks
  • 3,043 posts
Posted December 24, 2015 - 04:56 PM
Got it fixed the linkage was catching on the fuel line.
  • limebuzz, boyscout862, Oldford and 1 other said thanks
#7 dodge trucker ONLINE
dodge trucker
  • 2,421 Thanks
  • 3,115 posts
Posted December 24, 2015 - 09:31 PM
You talking about the Idle mixture screw?? the idle speed adjustment needs to be backed out to lower idle speed not screwed "in"  and the mixture screw isnt meant to regulate speed....
(though I see you got it fixed some may wonder about which idle screw you meant)
#8 bbuckler ONLINE
bbuckler
  • 3,421 Thanks
  • 3,043 posts
Posted December 24, 2015 - 09:54 PM
low speed idle screw
#9 dodge trucker ONLINE
dodge trucker
  • 2,421 Thanks
  • 3,115 posts
Posted December 24, 2015 - 10:10 PM
"low speed idle screw" sounds to me like you were trying to adjust idle speed with the mixture screw....
the idle speed adjustment usually bottoms against the throttle shaft on the top of the carb.
  • bbuckler said thank you
