1256/Wisconsin?
12 replies to this topic
#1 Oldford OFFLINE
Oldford
  • 1135 Thanks
  • 786 posts
Posted December 24, 2015 - 02:48 PM
Never had a bolens, there's a 1256 supposedly recently stopped running, looks complete, he's asking 150.   Another guy nearby has "tube frame attachments," 1256 is a tube frame, right?
So I'm wondering if these old Wisconsin bolens are cheap to keep running?   Parts still available, points, carb kits, etc...?
I'd just be putting a front blade on it for yard cleanup and tug.
i like the idea of having just a few hundred bucks tied up in a machine, instead of a couple thousand in the Case and JD...  any old GT is just one sheared bolt away from catastrophic failure....
appreciate any advice/info/tips, they look like cool little tractors, easy to move around, thanks for any help
  • Traill95, boyscout862 and chieffan have said thanks
#2 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted December 24, 2015 - 02:55 PM
This is going to have the TRA12D with solid state ignition
Almost All parts are available but ignition parts are getting pricey.
  • Alc, Oldford and chieffan have said thanks
#3 Toolfoole OFFLINE
Toolfoole
  • 270 Thanks
  • 145 posts
Posted December 24, 2015 - 03:07 PM
Bolens' are great machines, especially the tube-frames and large-frames. You can't go wrong for $150. The wheel weights alone regularly go for $125-$150+. Once you get it working, you won't regret your purchase. Good luck!
  • boyscout862, Oldford and chieffan have said thanks
#4 wilberj OFFLINE
wilberj
  • 5547 Thanks
  • 5736 posts
Posted December 24, 2015 - 03:10 PM
Those are off brand weights...
  • Oldford and chieffan have said thanks
#5 Toolfoole OFFLINE
Toolfoole
  • 270 Thanks
  • 145 posts
Posted December 24, 2015 - 03:48 PM
I noticed that right after I posted. Weights are always worth something, though. Usually a buck a pound, at least in this part of the country.
#6 chieffan OFFLINE
  • 15497 Thanks
  • 8820 posts
Posted December 24, 2015 - 04:15 PM
Do some serious checking on that solid state ignition before you jump in.   Also, like Dr. Bolens said, Parts are getting pricey.  Very pricey.
#7 Oldford OFFLINE
Oldford
  • 1135 Thanks
  • 786 posts
Posted December 24, 2015 - 06:33 PM
Well he said it "needs a coil and wiring is a mess" so that ain't sounding good.
What is worst case if all the electrics are fried?  How much work, how much in parts... thanks!
... i just picked up some bolens 12" weights for a buck a pound sounds like i did ok then.  has numbers on the back, nothing on the front, probly just as well i put them on a jd and painted them yellow
Edited by Oldford, December 24, 2015 - 06:37 PM.
  • chieffan said thank you
#8 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted December 24, 2015 - 07:39 PM
I'd be looking for a different machine, he likely fried the coil wiring it wrong maybe , your looking at $200 - $300 for a complete ignition overhaul
#9 Oldford OFFLINE
Oldford
  • 1135 Thanks
  • 786 posts
Posted December 24, 2015 - 10:32 PM
Are there any bolens singles with points and hydro lift?
#10 Bolens 1000 ONLINE
  • 17303 Thanks
  • 18797 posts
Posted December 24, 2015 - 10:39 PM
I believe all hydros were solid state ignition, the gear drives were mostly points ignition until they used the Tecumseh engines in the 70's but the gear drives had hydro lifts as optional equipment.
#11 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted December 25, 2015 - 07:50 AM
Check the head and be sure it is still good.
#12 chieffan OFFLINE
  • 15497 Thanks
  • 8820 posts
Posted December 25, 2015 - 08:43 AM
The manual lift is not bad at all if you have the helper spring kit on the tractor too.  I have a thrower on the front of a G12 with the lift assist and it is no problem to raise it one hand and I have bad shoulders.
#13 gardentractornut OFFLINE
gardentractornut
  • 325 Thanks
  • 322 posts
Posted December 25, 2015 - 01:15 PM
If the coil is bad, you could get a stock one but I bought this one:
http://www.ebay.com/...ARCH&rmvSB=true
It says it's NLA, but there's probably more out there. Works just fine, the only peeve of mine is it's so darn bulky. I ended up mounting it next to the battery, I don't seem to have a pic of it though.
I bought my 1254 non-running and once I got it running, it has been very reliable and man will it WORK! I love the TRA-12D, but I haven't had to do much with ignition. I would see if it's the coil, if so you shouldn't have much trouble bringing it back to life.
  • Oldford said thank you
