Will Mixing Fuel Work ?
11 replies to this topic
#1 chieffan OFFLINE
  • 11,357 Thanks
  • 7,112 posts
Posted December 23, 2015 - 09:09 AM
I have a contractor series forced air heater, torpedo type.  In the book it says it will burn several different type of fuel.  I have run Kerosene in it but with the price at $4.75 a gallon here I want to switch to #1 diesel, which it will burn.  Question is, do I have to burn all the Kerosene out before I fill with diesel or can I add 5 gal. of diesel to the couple gallons of Kerosene left in the tank.  The manual does not address this.  Anyone ? ?
  • Traill95 said thank you
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted December 23, 2015 - 09:25 AM
You can blend them.  One winter trick for diesel fuel is to add kerosine for better starting.
  • KennyP, HDWildBill, boyscout862 and 1 other said thanks
#3 Little Irish Men OFFLINE
Little Irish Men
  • 841 Thanks
  • 475 posts
Posted December 23, 2015 - 09:33 AM
:iagree:
Patrick.
#4 chieffan OFFLINE
  • 11,357 Thanks
  • 7,112 posts
Posted December 23, 2015 - 10:23 AM
Thanks guys.  I thought I could but wasn't sure.  Little over a buck a gallon difference.
#5 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted December 23, 2015 - 12:36 PM
I never understood why kerosene is so expense. 4.99 a gallon here! I used to use a little kerosene heater to supplement my heating with one but its not cost effective
#6 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted December 23, 2015 - 03:30 PM
I saw keep at Lowe's in a 5 gallon can at $44!!! Talk about expensive! Good for people who don't wanna get their hands dirty I guess.
#7 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted December 23, 2015 - 03:37 PM
Was that the odorless kerosene?
#8 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted December 23, 2015 - 03:58 PM
I didn't read the label, so maybe it was.
#9 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted December 23, 2015 - 04:00 PM
They called it like "kleen fuel". It was advertised as being completely odorless for use indoors. I always used regular k1 in my keresone mine inside and never had an issue
#10 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted December 23, 2015 - 04:03 PM
I used K1 in a heater when I waited 2 or 3 days for a furnace part a couple years back, and I didn't detect any sort of odor either.
#11 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,740 Thanks
  • 1,905 posts
Posted December 23, 2015 - 04:31 PM
I was always told odor was related to upkeep. If it stinks, then it needs an air filter, cleaned, etc.
Eric
#12 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,878 Thanks
  • 6,358 posts
Posted December 23, 2015 - 06:16 PM
Eric
That's what I always thought. I used the kerosun radiant style. Keep the wick trimmed, dry burn every so often , and make sure its set right and not over burning it.
  • dropped82 said thank you
