Simplicity Model D & Model L Interchangeability
model d model l simplicity
22 replies to this topic
#1 chrispg OFFLINE
chrispg
  • 129 Thanks
  • 78 posts
Posted December 20, 2015 - 10:40 PM
Can anyone tell me if the wheels and Gear Case for the Simplicity Models L and D are the same, interchangeable?
Can anyone tell from the attached cultivator pictures (only shots I have) if either will work for a Simplicity Model D?
Last, can anyone tell what the cutter bar in the attached picture goes to?
Edited by chrispg, December 20, 2015 - 10:43 PM.
  • Gtractor, Traill95 and boyscout862 have said thanks
#2 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted December 20, 2015 - 11:07 PM
Not 100% sure but I don't think the trannys are the same between "D" and "L".  Doubt they interchange.
Wheels should interchange no problem.  Might not be the exact same size but very close.
The cultivator at the back of the trailer is a Simplicity so yes it will work.
The sickle mower is Planet Jr.
The tractor pictured is a Bolens Power-Ho
Can't see the other cultivator good enough to identify - possibly a Simplicity also.
Edited by Gtractor, December 21, 2015 - 12:12 AM.
  • Alc, Lauber1, boyscout862 and 2 others have said thanks
#3 chrispg OFFLINE
chrispg
  • 129 Thanks
  • 78 posts
Posted December 20, 2015 - 11:23 PM
Thanks Gtractor. Im gonna take the risk and drive the 1.5 hours down to look at the stuff.
#4 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted December 21, 2015 - 12:14 AM
Best of luck in your pursuit  :thumbs:
Is the seller saying the tractor pictured is a Simplicity?  :(
  • chrispg said thank you
#5 chrispg OFFLINE
chrispg
  • 129 Thanks
  • 78 posts
Posted December 21, 2015 - 12:17 AM
No, he is not. Not sure what that one is. He has a Simplicity L ( not pictured) and a Planet Jr and some others.
  • Gtractor said thank you
#6 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted December 21, 2015 - 12:21 AM
Kewell!
Sounds like you need to take a trailer. :worshippy1:
#7 chrispg OFFLINE
chrispg
  • 129 Thanks
  • 78 posts
Posted December 21, 2015 - 12:31 AM
I'm just going for the Simplicity stuff. Got my pickup truck!
#8 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted December 21, 2015 - 12:41 AM
Not very familiar with the model "D" so measure the tranny - might be the same.
The other cultivator I'm thinking is a Simplicity also.  Hard to tell with that picture.
#9 karel OFFLINE
karel
  • 1,993 Thanks
  • 1,336 posts
Posted December 21, 2015 - 04:58 AM
I have parts for those,what are you looking for?
#10 chrispg OFFLINE
chrispg
  • 129 Thanks
  • 78 posts
Posted December 21, 2015 - 07:06 PM
I picked up an L frame today for $30 bucks and all of the drive train is complete.
Gtractor, the L drive train appears to be identical to the D and the gear box, wheels and hubs look to be same as the D size and appearance wise. I'll let you know once I have it apart! It has wheel weights (Lead?) and for sure they are good for the D, good ratchet hubs (I needed one too) and bushings.
The cultivator but was so rusted that is was scrap I think, unfortunately. He had already sold the other one....
Karl, what I'm really after is implements and PTO setup...
#11 chrispg OFFLINE
chrispg
  • 129 Thanks
  • 78 posts
Posted December 22, 2015 - 11:34 PM
Yup, L and D drivetrains are identical. Was able to poach all the bushings, seals, Hun stuff I needed.
#12 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted December 22, 2015 - 11:41 PM
Thats kewell!  Glad you were able to utilize the parts.
#13 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted December 23, 2015 - 01:21 PM
Is this what you call a PTO?
Edited by Gtractor, December 23, 2015 - 02:46 PM.
  • Lauber1 and chrispg have said thanks
#14 chrispg OFFLINE
chrispg
  • 129 Thanks
  • 78 posts
Posted December 23, 2015 - 05:02 PM
That is what I call a PTO!
#15 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,139 Thanks
  • 4,896 posts
Posted December 23, 2015 - 05:44 PM
This one is NOS.  Never had a belt on it and still has the patent numbers stenciled in yellow on the face of the flat belt pulley.
Also tagged with one or more of these keywords: model d, model l, simplicity
