Finally got an O
14 replies to this topic
#1 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted December 20, 2015 - 09:33 PM
Finally got a O this weekend to go with my 102 and 124. After a 7 hour round trip I got home with a 61 O serial # 12950 bolted spindles, no slot in the dash and what im assuming is the hole for the creeper lever. It needs some tlc but I couldn't be happier runs and drives great.
  • Bolens 1000, Gtractor, Alc and 11 others have said thanks
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted December 20, 2015 - 11:33 PM
I'd love to have that. Good find
  • Brando said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,818 Thanks
  • 4,308 posts
Posted December 21, 2015 - 02:22 AM
Great find, Brand-O   :smilewink:
#4 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted December 21, 2015 - 08:02 AM
Nice tractor. You going to restore or run it as is?
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted December 21, 2015 - 08:58 AM
That one deserves a restoration
#6 Bolens 1000 ONLINE
  • 15,540 Thanks
  • 18,316 posts
Posted December 21, 2015 - 09:31 AM
Nice Find, dosent look too bad
#7 EricFromPa ONLINE
EricFromPa
  • 4,297 Thanks
  • 3,413 posts
Posted December 21, 2015 - 03:05 PM
Is that a big crack in the top of the transaxle  1/2 way between the shifter plate and front of the transaxle? I know that the 4 mounting bolt holes crack out on the frame but I've never seen an O transaxle like that.
IH CC O did have a Hi/Lo range gear box available and that hole in the frame is for that.They are pretty hard to find.
They also had a 9 speed Under/Over drive available but they are very very rare.
  • Brando, BNK and Manfjourde have said thanks
#8 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted December 21, 2015 - 05:59 PM
Im going to just enjoy as is for now and work on the mechanicals and probably next spring give it some new paint.
  • JDBrian said thank you
#9 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted December 21, 2015 - 06:00 PM
Most definitely does, im going to just run it as is for now get the mechanicals done and paint in the spring.
  • BNK said thank you
#10 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted December 21, 2015 - 06:03 PM
No, its not a crack its a casting mark and no cracks in the frame.
  • EricFromPa, jpackard56 and BNK have said thanks
#11 BNK OFFLINE
BNK
  • 1,097 Thanks
  • 495 posts
Posted December 21, 2015 - 09:18 PM
Sweet find for sure. I had several in my time. I seen a M&W 9 speed with a missing or broken casting in the mount area sell on eBay a few years back for over $1,400. The item was just two counties east of me....I quit bidding at $500. By the way that #40 boxblade in the pic mounted on the "O" them rear tires is close to the implement?
  • EricFromPa said thank you
#12 EricFromPa ONLINE
EricFromPa
  • 4,297 Thanks
  • 3,413 posts
Posted December 22, 2015 - 12:24 PM
Yea sure is close.That O is sitting at an old Dealers shop.I doubt it ever gets used.
  • jpackard56 and BNK have said thanks
#13 BNK OFFLINE
BNK
  • 1,097 Thanks
  • 495 posts
Posted January 04, 2016 - 10:15 PM
That is too cool to walk in a dealership and see a Original...that started it all!
  • jpackard56 said thank you
#14 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted January 05, 2016 - 09:32 AM
Love to see another one saved :thumbs:
Just a note: since you said you are going to wait a while to tear into it, you might want to drain a little of the fluid out of trans-axle just to make sure it is not sitting with water in it like mine has been... see post "O Model Trans-axle Cleaning"
#15 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted January 05, 2016 - 09:33 AM
Where ? Might be worth a side trip sometime.
