Jacobson tractor Kohler K301 engine - $50 (East Lyme, CT)
13 replies to this topic
#1 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted December 20, 2015 - 09:35 AM
Wish that I could go for it but the van is in the shop. Good Luck to someone here. Rick
http://newlondon.cra...5367698055.html
Jacobson tractor Kohler K301 engine - $50 (East Lyme)
I have a Jacobson garden tractor with a Kohler K301 engine. No carb. What you see is what you get. Engine welded to frame. $50
Call/text 1-860-391-1203
  • Oldford said thank you
#2 KennyP ONLINE
  • 38,243 Thanks
  • 45,876 posts
Posted December 20, 2015 - 09:44 AM
An LGT 125 gear drive, '72-'76
#3 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted December 20, 2015 - 09:46 AM
Any Kohler K series is worth saving!
Someone go get it!
#4 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted December 20, 2015 - 10:57 AM
I think its an LGT120 because it looks to be gear drive and is manual lift. If I make progress on the van, I may call. I could sure use a bunch of parts from that for my LGT120, LGT125, and LGT145. I'd rather see someone here get it than lose it. Good Luck, Rick
#5 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted December 20, 2015 - 10:58 AM
Why would someone weld the engine to the frame??
  • Gtractor said thank you
#6 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted December 20, 2015 - 11:08 AM
Jacobsen did that at that time. It probably saved money in the production line. They are a particular model of the Kohler engines. Most Kohlers will not fit. Good Luck, Rick
  • Bolens 1000 said thank you
#7 KennyP ONLINE
  • 38,243 Thanks
  • 45,876 posts
Posted December 20, 2015 - 05:27 PM
Well, I was close! :bigrofl:
#8 poncho62 ONLINE
poncho62
  • 1,728 Thanks
  • 1,657 posts
Posted December 20, 2015 - 05:45 PM
I have paid more for less.......and less for more
Definitely a gear drive. Those are getting harder to find
  • boyscout862 and Oldford have said thanks
#9 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted December 20, 2015 - 07:32 PM
Welded because the engine plate with rubber mounts was gone, and no other mounts for rigid mounting?? OR, is that plate after this models year?  Some people will Kobble anything just to make it work, right or wrong.
#10 poncho62 ONLINE
poncho62
  • 1,728 Thanks
  • 1,657 posts
Posted December 20, 2015 - 08:29 PM
They came from the factory that way.... the pan also serves as the cross member for the front suspension
Edited by poncho62, December 20, 2015 - 08:30 PM.
  • limebuzz, KennyP, boyscout862 and 1 other said thanks
#11 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted December 21, 2015 - 07:07 AM
This was a class act!! And made for a very stout frame to engine combo. The oilpan/ front axle pivot is also very robust. As you can see the engine unbolts very easily, also this allowed for more oil in the pan too. I think is was the best design at the time. Not so good for allowinga retro engine swap though.
#12 MarksA-C OFFLINE
MarksA-C
  • 265 Thanks
  • 99 posts
Posted December 21, 2015 - 09:07 PM
Some gilsons had the briggs oil pan as part of the frame.
#13 dodge trucker ONLINE
dodge trucker
  • 2,423 Thanks
  • 3,116 posts
Posted December 24, 2015 - 10:03 AM
the pan looks like typical cast iron material like any other K series single.  What material is the frame?  How would they be able to weld cast iron to mild steel? (dissimilar metals)
#14 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted December 27, 2015 - 03:15 PM
I called the guy on Thursday and he still had it. Another guy had first dibs but kept pushing back when he would come. I told him to call me if it didn't sell. He called last night and I picked it up today. It is in sadder sheet metal condition than I had hoped. The engine turns and doesn' seem to have any obvious bad problems. He also had a cart that I bought.
Its funny, I thought that that Jake would sell the same day it was posted. I didn't think I would get it. Hopefully it will provide the parts to fix my Ford LGT 120. Good Luck, Rick
Edited by boyscout862, December 27, 2015 - 04:04 PM.
