Steam Power in the Christmas Village
27 replies to this topic
#16 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted December 20, 2015 - 06:02 PM
The guys that build small steam engines around here run them on compressed air. A lot less mess.
I will like to figure out how to run my on air for the tractor show and run in the house. They don't like it when I run it in the house it has a bad smell.
#17 MH81 OFFLINE
  • 29,978 Thanks
Posted December 20, 2015 - 08:11 PM
The little Esbit tabs had no noticeable smell
I think the ones I had were 4g size, but you can see what other sizes are available
It is still a fire and all that, but not stinky.
  • bbuckler said thank you
#18 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted December 20, 2015 - 08:24 PM
Yep I think burning 91% alcohol is my problem. They sell the burners for mine to switch to Esbit tabs but I still like to find out how to run it on air so I can take it to shows.
#19 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,115 Thanks
  • 10,186 posts
Posted December 20, 2015 - 09:12 PM
In the picture of Alan's set up, there is a line running from the boiler to the engine. Can you disconnect that and attach a plastic line from the air pump? Or can you splice into it?
#20 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted December 20, 2015 - 09:24 PM
Mine has the line soldered to it the engine it located on top of the boiler.
#21 MH81 OFFLINE
  • 29,978 Thanks
Posted December 20, 2015 - 09:25 PM
I would think the best place to do it would be screwing in a line where the steam whistle is. That would leave the pop off in place without altering the plumbing.
#22 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted December 20, 2015 - 09:30 PM
I think that would work and I can probably find a barbed fitting at lowes or home depot.
#23 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,115 Thanks
  • 10,186 posts
Posted December 20, 2015 - 09:42 PM
How is the speed controlled?
#24 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted December 20, 2015 - 09:46 PM
No way to on this one. it shown 2200 rpms on steam
#25 MH81 OFFLINE
  • 29,978 Thanks
Posted December 20, 2015 - 09:53 PM
Psi would control it.
On a real steam engine, not sure
#26 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted December 20, 2015 - 10:20 PM
I just read the best thing to use is a airbrush compressor.
#27 Leonard VanCamp ONLINE
Leonard VanCamp
  • 658 Thanks
  • 474 posts
Posted December 20, 2015 - 10:41 PM
The full size one use a governor activated valve to regulate the amount of steam going to the piston.
#28 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,115 Thanks
  • 10,186 posts
Posted December 21, 2015 - 08:10 AM
Tf you go to the pet shops , they have a valve to control the air flow.  Also, check with http://www.drsfoster...plies/pr/c/3578
