Briggs model info
1 reply to this topic
#1 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted December 18, 2015 - 09:35 PM
Here is all the model info on Briggs and stratton engines
The numbers are stamped in the shroud
The first number and the second number are the displacement.
The first digit after displacement is the basic design series
The next digit (second digit after displacement) is the crankshaft, Carb. and governor.
Next digit ( The third arter displacement) is the bearings, reduction gears And auxillary drives.
The last digit is the type of starter.
The cubic inches go from 0 to 32
The design series goes from 0 to 9
The crank, carb and governor go from 1 to 9
This is what they stand for
  1. Horizontal Vacu-jet
  2. Horizontal Pulsa-Jet
  3. Horizontal Flo-jet (pneumatic governor)
  4. Horizontal Flo-Jet (Mechanical governor)
  5. Vertical Vacu-jet
  6. None
  7. Vrtical Flo-jet
  8. None
  9. Vertical pulsa-jet
Bearings, Reduction gears and auxillary drives
0. Plain bearing
  1. Flange mounting plain bearing
  2. Ball bearing
  3. Flange mounting ball bearing
  4. None
  5. Gear reduction (6 to 1)
  6. Gear reduction (6 to 1) Reverse rotation
  7. None
  8. Auxillary drive perpendicular to crankshaft
  9. Auxillary drive parallel to crankshaft
Type of starter
0. Without starter
  1. Rope starter
  2. Rewind starter
  3. Electric 110 volt gear drive
  4. Electric starter generator 12 volt belt drive
  5. Electric starter only-12 volt gear drive
  6. Alternator only*
  7. Electric starter 12 volt gear drive with alternator
  8. Vertical pull starter
*Digit 6 formerly used for "Wind up" starter on 60000,80000 and 92000 series
An example would be 170707
17 Cubic inches
Design series 0
Vertical flo-jet
plain bearing
And an electic starter with alternator
Edited by 637Yeoman, December 19, 2015 - 12:37 PM.
  • CRFarnsworth, TimW and Genem have said thanks
#2 chieffan ONLINE
  • 10,164 Thanks
  • 6,642 posts
Posted December 19, 2015 - 05:32 AM
That is the Model number designation only.  The code number tell you when it was built if built after 1965.  yr-mo-dy-plant & assembly line.
  • 637Yeoman said thank you
