Sort of Garden Tractor
snow gear
2 replies to this topic
  • 187 Thanks
  • 268 posts
Posted December 18, 2015 - 09:48 AM
I plow my garden with so it`s a Garden Tractor ...Right ??
Since this is one more active forums for Fords I thought would get the word out here too.
I got a Ford 1520 a while back and it came with front mount 6 foot scraper blade. W
e just occasionally get enough snow to bother with scraping ,It usually melts off in a day or two. So I really don`t need it.
I thought I would post it here since a lot you Guys live in snow country.
It is New Holland 702C Hyd Lift/Tilt with a 6 foot spring loaded Scraper. It mounts under the tractor at about the drivers seat and the front of the frame with the lift cylinder mounted to front bumper. it is set up for manual tilt but you can add cylinder to hyd tilt the blade. I used it to clean up some scruffy vegetation and push some big logs around. It pretty tuff and with the spring loaded blade you do some work.  It would be good for Barnyard clean up or spread gravel or loose dirt. Lot of things you could probably do with it.
I need to get $ 900 out of it ...can`t find out what they cost new but I would say it would be upwards of $2000.. Could probably remove blade and pack it up on a big pallet with some overhang for shipping LTL.
If interested post here and we`ll get together on phone or email me.
  • hamman and Traill95 have said thanks
#2 KennyP ONLINE
  • 39,165 Thanks
  • 46,325 posts
Posted December 18, 2015 - 10:06 AM
I moved this to the Classifieds. For sale ads need to be here.
  • DougT said thank you
  • 187 Thanks
  • 268 posts
Posted January 05, 2016 - 08:10 PM
thanks KP....I`ll do better!
  • limebuzz and KennyP have said thanks
