* * - - - 2 votes
Cub Cadet 1650
45 replies to this topic
#16 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted December 17, 2015 - 01:18 PM
The idle needle is bent and the points have no air gap.
  • KennyP and SC Farmer have said thanks
#17 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted December 17, 2015 - 04:50 PM
ImageUploadedByTapatalk1450389006.457607.jpg ImageUploadedByTapatalk1450389019.436517.jpg ImageUploadedByTapatalk1450389034.129969.jpg ImageUploadedByTapatalk1450389044.564698.jpg
  • Bolens 1000, BNK, Marty'70 and 1 other said thanks
#18 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted December 17, 2015 - 11:21 PM
Anybody know the part number for the rear cover plate ?
  • SC Farmer said thank you
#19 KennyP ONLINE
  • 40,103 Thanks
  • 46,756 posts
Posted December 18, 2015 - 05:33 AM
Just looked it up here. The cover plate is IH-394089-R11. Gasket is IH-350837-R2.
  • bbuckler and SC Farmer have said thanks
#20 BNK OFFLINE
BNK
  • 1,097 Thanks
  • 495 posts
Posted December 18, 2015 - 06:54 AM
Sounds like some good advice, and all fairly easy to do. So now it's my turn to poop on your parade. Check the ISO mounts if you haven't already as well as the rag joint. Cause "if" the mounts are bad, which most times they are, so is the rag joint from the engine hopping around...
But who knows, yyou may be the lucky one...
Remember when you change the filter to get a hydraulic filter, not an oil filter. Not getting into the HyTran debate. I use only HYTran, always have and always will.
I use CarQuest filters, 85410 or
NAPA FIL1410
Cub Cadet 923-3014 723-3014
I brought home a Quietline one time...ISO mounts worn soo bad that the air breather wing nut stem worn a hole in the engine side cover. The exhaust duct sheet metal took a beating and the driveline to include the drive shaft clevis at the pump. It was a 1250 CC and 12 yrs later I have it to this day.
#21 IHCubGuy ONLINE
IHCubGuy
  • 1,590 Thanks
  • 1,629 posts
Posted December 18, 2015 - 06:16 PM
That's a NICE 1250 there BNK.  Maybe I'm just crazy but I think that the quietlines are the prettiest Cub Cadet that IH ever made.  I have been a fan of them since I was young.  I had a 1450 ten years ago and got rid of it.  In hindsight I wish I would have kept it and I hope to have another one someday.
  • BNK and SC Farmer have said thanks
#22 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted December 20, 2015 - 07:07 PM
We should have it up and going at Christmas nothing better to do while waiting on Christmas dinner.
#23 SC Farmer OFFLINE
SC Farmer
  • 244 Thanks
  • 156 posts
Posted December 21, 2015 - 07:13 PM
I only use IH/Case hydraulic/trans fluid in my '51 Cub, same for my Cub Cadet 106.  Very competitive price at True Value Hardware: @$18.99 for 2 gallons and you can get it in-store or online!
Check it out:
http://www.truevalue...keyword=hy tran   Lube King Hydraulic Fluid, Case IH, 2-Gals.
  • Marty'70 said thank you
#24 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted December 25, 2015 - 11:15 PM
Should have it finished tomorrow and then install the tiller.
#25 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted January 19, 2016 - 12:11 AM
We ended up make a gasket so far no leaking. The choke cable is messed up and keeps going back into choke.
#26 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted January 20, 2016 - 03:38 PM
Test driving today
#27 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted January 20, 2016 - 03:44 PM
It loud I think it needs a new muffler.
  • KennyP and BNK have said thanks
#28 KennyP ONLINE
  • 40,103 Thanks
  • 46,756 posts
Posted January 20, 2016 - 05:35 PM
Good to see it getting some excercise!
  • BNK said thank you
#29 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted January 24, 2016 - 09:30 PM
We are working on the electric pto next weekend and mounting the tiller. Found a mule drive for it got to order it and the belt.
#30 bbuckler ONLINE
bbuckler
  • 3,661 Thanks
  • 3,192 posts
Posted January 28, 2016 - 12:51 PM
Got the mule drive ordered. This weekend we are rewiring since there is a lot of wire piece together.
