* * - - - 2 votes
Cub Cadet 1650
45 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,990 posts
Posted December 16, 2015 - 05:58 PM
My uncle got his 1650 today. Now to get it ready for spring
Do List :
Clean and Rebuild Carb
Check and Adjust Points
New Battery
Fluid up the rearend and find where it leaking
Maybe more added to the list I hope not but yall know how it goes when you start working on one.
Pictures coming soon
  • Bolens 1000, KennyP, propane1 and 3 others have said thanks
#2 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 853 Thanks
  • 715 posts
Posted December 16, 2015 - 06:46 PM
Make sure you use the correct hyd fluid for the tranny.
  • SC Farmer said thank you
#3 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,990 posts
Posted December 16, 2015 - 06:58 PM
I used some off brand hy-tran from tractor supply the last one I had and no problems
  • chieffan and SC Farmer have said thanks
#4 glgrumpy ONLINE
  • 8,564 Thanks
  • 7,882 posts
Posted December 16, 2015 - 07:03 PM
Cadets leak where the main pump is mounted on front of the trans. There is a cork (I think) round gasket there, and can leak after long use. Have to release 4 long bolts to pull it back enough for gasket. Have to be careful when positioning and tightening again. Might want to also look at those rubber engine cradle mounts. Many times they are weak or broken out and driveline is not lined up as well, and the engine shakes or vibrates thru chassis when metals are hitting hard at those points.
  • bbuckler, chieffan, Marty'70 and 1 other said thanks
#5 Marty'70 OFFLINE
Marty'70
  • 853 Thanks
  • 715 posts
Posted December 16, 2015 - 07:16 PM
Jus saying that I have heard stories about how Cubs are finicky and don't like off brand oils. Just did a he filter and tranny fluid in my 1650 and buckled down for the Cub oil as much as I hated paying that much for it. My 2¢ worth.
  • BNK and SC Farmer have said thanks
#6 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,990 posts
Posted December 16, 2015 - 07:42 PM
Does tractor supply sell it ?
#7 Marty'70 OFFLINE
Marty'70
  • 853 Thanks
  • 715 posts
Posted December 16, 2015 - 07:56 PM
What I put in mine. Looked at TSC website and they didn't list it. May have to check with your local store. Got mine from local Cub dealer. Right next to TSC in town and alot of the time is cheaper.
#8 Marty'70 OFFLINE
Marty'70
  • 853 Thanks
  • 715 posts
Posted December 16, 2015 - 07:57 PM
BTW it takes 7 qts fora complete fluid change
#9 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted December 16, 2015 - 08:00 PM
Nope.  Go to a CaseIH dealer and ask for Hy-Tran Ultraction.  Can sometimes find it at independent Cub Cadet dealers to.  Thats the lateset version of what was in it from new.  Hy Tran is formulated to absorb 1% of its volume in water, it has properties as an o ring swelling agent to keep them tight, it's anti foaming and it will rid itself of air as well.  It is a much better fluid than what TSC or anyone else for that matter has as a "Universal" fluid.
Edited by IHCubGuy, December 16, 2015 - 08:02 PM.
  • bbuckler, BNK, Marty'70 and 1 other said thanks
#10 Marty'70 OFFLINE
Marty'70
  • 853 Thanks
  • 715 posts
Posted December 16, 2015 - 08:48 PM
Hey CubGuy, so did I get the wrong stuff oris it the same as the Hy-Tran.
http://gardentractor...13648_thumb.jpg
#11 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,990 posts
Posted December 16, 2015 - 08:53 PM
It a hour drive to the nearest case dealer
#12 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted December 16, 2015 - 10:34 PM
some better parts stores (forget  about Advance and Useless Zone) have, or can get, the exact stuff if you "gotta have" exact OEM.
Edited by dodge trucker, December 16, 2015 - 10:35 PM.
  • bbuckler and SC Farmer have said thanks
#13 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted December 16, 2015 - 11:25 PM
Same stuff packaged for MTD and sold with a Cub Cadet sticker instead of an IH one.  I am so used to just buying the 5 gallon jugs of it since I use it in several different things including my big farm tractors.
  • KennyP, Marty'70 and SC Farmer have said thanks
#14 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted December 17, 2015 - 01:03 AM
Sounds like some good advice, and all fairly easy to do. So now it's my turn to poop on your parade. Check the ISO mounts if you haven't already as well as the rag joint. Cause "if" the mounts are bad, which most times they are, so is the rag joint from the engine hopping around...
But who knows, yyou may be the lucky one...
Remember when you change the filter to get a hydraulic filter, not an oil filter. Not getting into the HyTran debate. I use only HYTran, always have and always will.
I use CarQuest filters, 85410 or
NAPA FIL1410
Cub Cadet 923-3014 723-3014
  • KennyP, dodge trucker, bbuckler and 2 others have said thanks
#15 chieffan ONLINE
  • 9,627 Thanks
  • 6,437 posts
Posted December 17, 2015 - 08:33 AM
Northland is one of the best oils around, bar none.  A ton of farmers around here buy it in bulk containers of 250 gallons each, one of transmission fluid and one of engine oil (diesel) and use it in everything they own, all equipment brands, colors, and configurations.  None of those "Name Brand" oils are made by that brand anyway,  they contract with the big boys to buy their products with their fancy label on it and then charge you for the label.  There are only about 5 or 6 oil producing companies to start with, if that many.  Buy enough and they will put YOUR name on a bunch of quart jugs.
