* * * * * 1 votes
Building another puller Rip & Tear II
95 replies to this topic
#31 IHCubGuy OFFLINE
IHCubGuy
  • 1,591 Thanks
  • 1,631 posts
Posted January 18, 2016 - 08:36 PM
Excellent!
  • DaveBb, sherylky4, phillipnx69 and 2 others have said thanks
#32 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted January 19, 2016 - 01:26 PM
Was not sure how I would do the steering end of the hood and match up the 15 in hood to the 11 inch frame. Last night in bed it came to me lol. Got at it first thing this morning. I capped the frame and made it look two inches wider on each side. Used brackets to hold it to frame. This part will be buffed not painted. I cut the rear end of hood to match the front angle to keep the lines right.
  • Alc, wvbuzzmaster, KennyP and 2 others have said thanks
#33 Cvans ONLINE
  • 7,075 Thanks
  • 6,293 posts
Posted January 19, 2016 - 02:20 PM
Sure looks nice so far. Thanks for letting us follow along.
  • DaveBb said thank you
#34 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted January 20, 2016 - 02:44 PM
Worked on closing in the nose today. I am glad I notched the frame so the fuel tank won't block to much of the grill. Added a 1/4 flat stock bumper just in case. These parts will be buffed not painted. Next up is the pod and dash panel.
  • Alc, wvbuzzmaster, sacsr and 1 other said thanks
#35 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 20, 2016 - 02:50 PM
You may have missed my question, but how did you make that nose?
#36 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted January 20, 2016 - 08:00 PM
The nose cone I used a fine pressed wood with three coasts of epoxy resin the first coat having glass hair cut into it. A little unconventional but turned out pretty good. The resin is very strong.
  • olcowhand, Alc and KennyP have said thanks
#37 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 20, 2016 - 08:03 PM
It turned out GREAT!
  • Cvans and DaveBb have said thanks
#38 WIGTPuller OFFLINE
WIGTPuller
  • 8 Thanks
  • 12 posts
Posted January 20, 2016 - 08:27 PM
VERY nice!  Thank you for "bringing us along for the ride"!  Keep the pictures coming! :thumbs:
#39 TAHOE ONLINE
TAHOE
  • 8,173 Thanks
  • 5,760 posts
Posted January 21, 2016 - 08:33 AM
Wow, amazing work. that looks great!
#40 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted January 21, 2016 - 02:03 PM
Worked on getting things lined up and bolted today on the hood. I used 1/4 round head bolts that I will buff a bit and not paint. I made it so 4 bolts remove the complete unit. With all the angles it has turned out to be very solid..There will be a master plug for wiring between the hood and tractor so it should be easy to remove.
Edited by Saxist, January 21, 2016 - 02:04 PM.
  • olcowhand, wvbuzzmaster, skyrydr2 and 1 other said thanks
#41 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted February 12, 2016 - 02:21 PM
Well got some more done on the beast... I installed a drive shaft support bearing, made the dash and tunnel cover. Sheet metal is about done except for the side covers that I will do once the engine is in place. Had my injection pump opened up from 26cc to 100cc. At the moment waiting on my billet flywheel from the machine shop then I can get the engine in place.
Edited by Saxist, February 12, 2016 - 02:23 PM.
  • wvbuzzmaster, sacsr and backwoods have said thanks
#42 BNK OFFLINE
BNK
  • 1,097 Thanks
  • 495 posts
Posted February 12, 2016 - 05:23 PM
OMG!!!! Another custom build to watch!!! SWEET!!!!
#43 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted February 21, 2016 - 05:25 PM
Well time to do some painting. Waiting on billet flywheel and some other odds and ends so figure I will paint it. It will be Allis orange except these parts I will buff this to chrome.  Was pretty happy I can strip it down to the frame in under 30 mins. Looks pretty naked without the panels lol. Painting aluminum is alot more time consuming with the extra prep work involve.
Edited by DaveBb, February 21, 2016 - 05:29 PM.
  • EricR and Dieselcubmike have said thanks
#44 metcalf OFFLINE
metcalf
  • 2 Thanks
  • 4 posts
Posted February 21, 2016 - 07:20 PM
Wow that is great. You do this. It is real neat to see things come along. One question who did you have work on your injection pump?
#45 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted February 25, 2016 - 04:27 PM
Injection pump was done by a local person up here in Quebec. Well got the aluminum all cleaned up and primed with epoxy then a coat of build primer it took a few days. Today I painted her but could not bring myself to paint it just simple orange lol. I went with a copper orange pearl color. I did three base coats and 4 clear coats to give me some room to buff it some. The next few days will be buffing the remaining aluminum parts to a chrome.
Edited by DaveBb, February 25, 2016 - 04:35 PM.
  • olcowhand, KennyP, IHCubGuy and 1 other said thanks
