Ammeter question.
8 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 15, 2015 - 07:21 PM
Will this work on a 214? If so how do I wire it up?
Thanks
#2 KennyP OFFLINE
  • 41,455 Thanks
  • 47,383 posts
Posted December 15, 2015 - 08:01 PM
See if this helps.
#3 toppop52 ONLINE
toppop52
  • 5,594 Thanks
  • 4,940 posts
Posted December 15, 2015 - 08:08 PM
Honestly, a volt meter is safer, easier to wire and gives more useful information.
  • Marty'70 and coinman66 have said thanks
#4 BigFlash ONLINE
BigFlash
  • 248 Thanks
  • 134 posts
Posted December 15, 2015 - 09:11 PM
That should fit in the hole no problem. The issue i think you might run into is instead of two wire terminals that bolt on the back of the meter like the gauge you have there. The deere meter you simply push a section of wire into a grove on the back of the gauge. So your wiring harness likely won't have terminals to connect to that gauge.
#5 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 15, 2015 - 09:31 PM
Yah it fits in hole ok. I didn't have a guage, it was missing so I bought this. So are u saying I can use this but just hook wiring to one terminal?
#6 BigFlash ONLINE
BigFlash
  • 248 Thanks
  • 134 posts
Posted December 15, 2015 - 09:48 PM
There deere ones were an inductive type that didn't require any ring terminals, The picture below should help.
 You would likely need to cut the wire that would normally get pushed into the back of the meter  and install two ring terminals onto those cut ends and attach them to your new ammeter
  • Alc, KennyP and coinman66 have said thanks
#7 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted December 15, 2015 - 10:17 PM
I think the + side should be connected to the wire that comes from the battery.  - side to the switch.  to make to work right.
#8 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 15, 2015 - 10:28 PM
Got it guys. Had a looped red wire on my harness that I believe started at ignition swithch, so I cut that loop, installed round wire terminals and hooked it to each guage posts. Now when I turn the key on it points to the negative and when it starts and throttle it up it points to the positive side.
Thanks for all your help!
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted December 16, 2015 - 09:04 AM
Sounds like it works!
  • coinman66 said thank you
