Got a Freebie Perkins
47 replies to this topic
#16 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted December 15, 2015 - 08:02 AM
Is that one of the Rigmaster's. Used to do a second job doing maintenance for a local diesel shop. They put a lot of those in.
Yes, it's Rigmaster.  And a couple years back I uploaded a manual for this engine.  You can find it HERE.
  • OldAllis52 said thank you
#17 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted December 15, 2015 - 08:15 AM
OK, not sure what this is. Looks like maybe could make a home-made tractor, using ALL that assembly for the hood and front, then have cab with heat and A/C then??
GL , it's a self contained cooling unit off a semi. Pull the motor and drop in a GT of your choice!
#18 OldAllis52 OFFLINE
OldAllis52
  • 273 Thanks
  • 160 posts
Posted December 15, 2015 - 08:55 AM
Yeah it is a Rigmaster. They were the biggest seller untill Thermo King and Carrier came out with their units. Rigmastet could not compete with their network and went in and out of bankrupt court several times until finally closing. They had a reputation for being unreliable but the engines never gave trouble just the other systems.There are more of these showing up now so there might be a new wave of repowers coming. I know if a few that have been used to run pumps and other things that need cheap steady power. To the other question about the hours. There is no hour meter ob the unit. I believe it was ib the control panel in the cab and that was not with the one I have.
#19 Cvans ONLINE
  • 7,310 Thanks
  • 6,392 posts
Posted December 15, 2015 - 10:08 AM
You sure walked into a bed of roses there.   :thumbs:    Hope you can find a good home for it.  Let us know when the project starts.  :D
#20 OldAllis52 OFFLINE
OldAllis52
  • 273 Thanks
  • 160 posts
Posted December 15, 2015 - 04:22 PM
Got all the a/c hoses and un-needed wiring stripped off today. Engine was stuck from sitting several years so I pulled the injectors and squirted unstickum down into the cylinders. Came home this afternoon and rocked it a little bit and she broke free. I squirted a little more stuff in the cylinder to make sure everything gets slick. I hope to have time to start it in the next day or two. Only battery I have is an 8D with 1400 cca so I might have enough to crank it a couple of times.
  • olcowhand, Texas Deere and Horse, KennyP and 1 other said thanks
#21 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted December 16, 2015 - 08:04 AM
unstickum
Is that a brand name and where can we find it? :poke:  :poke: :D  :D
Good to hear she broke free.
#22 OldAllis52 OFFLINE
OldAllis52
  • 273 Thanks
  • 160 posts
Posted December 16, 2015 - 08:57 AM
Home made half trans fluid and half acetone.
  • KennyP and TAHOE have said thanks
#23 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted December 16, 2015 - 09:19 AM
Good stuff there! Use it a bunch!
#24 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted December 16, 2015 - 09:20 AM
I believe that's called "Kennytrating Fluid"!   :smilewink:
  • KennyP, JDBrian, Cvans and 1 other said thanks
#25 KennyP ONLINE
  • 41,004 Thanks
  • 47,162 posts
Posted December 16, 2015 - 09:31 AM
Best part is it works!
#26 OldAllis52 OFFLINE
OldAllis52
  • 273 Thanks
  • 160 posts
Posted December 17, 2015 - 06:06 PM
I'm hoping to crank the little bugger tomorrow after I get a line made up for the oil gage. Spent today separating the wires for the starter,alternator,glow plugs, and on/off switch from the harness. In the morning I'm going to wire in the cooling fan which I checked out today. I also mounted a fuel tank today and plumbed the return line. Hoping to make some smoke tomorrow. I had to take a fuel pump off a big Massey to the pump shop yesterday and found out they are a Perkins dealer. They said they could get me anything I need. I said "how abour a turbo"? They said anything is possible.
  • olcowhand and KennyP have said thanks
#27 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted December 17, 2015 - 06:18 PM
Looking forward to hearing it rumble!
#28 Cvans ONLINE
  • 7,310 Thanks
  • 6,392 posts
Posted December 17, 2015 - 11:05 PM
I don't know why you guys waste your time on these smoke belching, noisy, and smelly diesels. :(
#29 OldAllis52 OFFLINE
OldAllis52
  • 273 Thanks
  • 160 posts
Posted December 18, 2015 - 06:41 PM
No belching smoke today. Had to work late and forgot to pick up diesel. :wallbanging:
  • olcowhand said thank you
#30 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted December 18, 2015 - 07:02 PM
Awe man!   :boo_hoo:  :ah_shoot: Maybe tomorrow then?   :smilewink:
