Purchasing a GT Jacobsen
27 replies to this topic
#1 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 12:38 PM
Hello My name is Roger. I am looking at purchasing a Jacobsen Gt 14 hp with a Koler engin. This tractor comes with implements like a roto tiller and a ground plow. My question is, will a 14Hp really have enough power to pull a one farrow ground plow?
Thank you
Roger
#2 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 12:40 PM
This tractor also has a snow plow attachment that is 48", were these smaller tractors powerfull enough to handel that much weight?
#3 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 12:42 PM
Pictured in this ad is also a 8 disc harrow. I am spectical about the size of the harrow's to the size of the tractor.
#4 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 12:44 PM
The picture of the Roto tiller looks like there is a PTO shaft instead of an indipendant power supply, is this possiable?
#5 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 12:48 PM
Would there be carb rebuild kits avialable for these older Koler engines?
#6 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,284 Thanks
  • 1,435 posts
Posted April 22, 2011 - 12:57 PM
A giant yes to all above ? , Raveman. If it is runs right , it will have no problem with the implements. They are a very good machine. Welcome to the forum and we love pictures!
Edited by tractorgarden, April 22, 2011 - 01:03 PM.
#7 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 12:59 PM
Thank you.
WWould you beable to identify this model?
#8 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 01:01 PM
Here are the implements, do they look like they belong to this tractor?
#9 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 01:03 PM
#10 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 01:04 PM
#11 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 01:05 PM
#12 RAVeman OFFLINE
RAVeman
  • 16 posts
Posted April 22, 2011 - 01:07 PM
#13 Chuck_050382 OFFLINE
Chuck_050382
  • 273 Thanks
  • 1,498 posts
Posted April 22, 2011 - 01:22 PM
That is same as the open side for LGT 145. It is a very cappable machine. The tractor in my avatar is a 14 hp ford lgt 145 It is a closed side model which is a little newer, but pretty much the same under the skin.
here is video of it plowing.
#14 Chuck_050382 OFFLINE
Chuck_050382
  • 273 Thanks
  • 1,498 posts
Posted April 22, 2011 - 01:24 PM
and yes the tiller, sleeve hitch and snow plow all belong with that tractor and were made by jacobsen.
the plow and disc are probably Brinly which will work with any GT with a sleeve hitch or sleeve hitch adapter on a 3pt hitch.
#15 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,284 Thanks
  • 1,435 posts
Posted April 22, 2011 - 01:31 PM
:ditto::iagree:Thanks for the pictures.
