Brinly row crop cultivator
7 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,587 Thanks
  • 1,463 posts
Posted December 14, 2015 - 10:44 AM
I'm referring to the V shaped one. How well does it work? Does it clear the crops? It looks like it should work well... I just don't think the sleeve hitch arm would clear the crops
  • chieffan said thank you
#2 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted December 14, 2015 - 11:19 AM
what kind of crops? corn?
#3 Greasy6020 OFFLINE
Greasy6020
  • 1,587 Thanks
  • 1,463 posts
Posted December 14, 2015 - 11:43 AM
Corn carrots beets anything that could be considered a row crop
#4 chieffan ONLINE
  • 10,874 Thanks
  • 6,910 posts
Posted December 14, 2015 - 11:51 AM
I have two that I use.  One has the David Bradley shovels on it, and the other has the narrower points I use more for tearing the ground up.  If you can find some old horse drawn cultivator sweeps or shovels, they will bolt right on the round shanks.  Need about 1/3 overlap to be sure you cover the whole area.  I use the sleeve hitch mounted in the bottom hole to raise it up.  If the tractor clears so will the cultivator.
#5 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted December 14, 2015 - 12:16 PM
dependingon how high the crop is it shouldn't hit
#6 MH81 OFFLINE
Posted December 14, 2015 - 12:18 PM
You can use them until the crops are a couple inches higher than clearance.
:ditto: on the sweeps making a difference
the OEM sweeps are OK if used regularly. also, I would suggest adding some weight on the back of the cultivator.
BTW, you will be playing with the length of the sweeps to get them all working together.
  • 637Yeoman said thank you
#7 Greasy6020 OFFLINE
Greasy6020
  • 1,587 Thanks
  • 1,463 posts
Posted December 14, 2015 - 08:22 PM
Ok thanks for the help!
#8 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted December 19, 2015 - 09:04 PM
Add weight to cultivator. And I did our sweet corn till it was about 12 to 15 inches with no problems. And yes to get the sweeps set right will take days lol. Glad I only use mine oOn the 140
