Ford LGT 195 Build
ford lgt 195 tractor
36 replies to this topic
#31 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted June 04, 2016 - 02:36 PM
Glad to see your still posting. What issues are there with the Kubota?
#32 MarksA-C OFFLINE
MarksA-C
  • 268 Thanks
  • 100 posts
Posted June 05, 2016 - 12:27 AM
Missing flywheel, starter, carb, alternator, and distributor.  Need all those before I can ever even test fire it.
SO the choice is hundreds upon hundreds of dollars into the engine to make sure it worked before I ever get it installed OR direct bolt in swap for a NOS kohler that is the proper engine for the tractor and its done.  Its an easy enough choice for me seeing how my finances are very thin.
  • Alc, KennyP, TomLGT195 and 1 other said thanks
#33 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted June 05, 2016 - 12:45 AM
I want a 195 or Jake equivalent. Great thread,I'm subscribing...
#34 Jack's Tracs OFFLINE
Jack's Tracs
  • 1 posts
Posted June 16, 2016 - 04:15 PM
Following!
I own a '74 Ford LGT 125 , similar frame as your later (and somewhat larger) 195 - and minus the hydraulics and PTO. These things are beasts and can accept a FEL( usually used the Johnson loader).
Mine is a "work in progress" too, and understand financial constraints all to well. Just plug away as you can :-)
#35 MarksA-C OFFLINE
MarksA-C
  • 268 Thanks
  • 100 posts
Posted June 27, 2016 - 12:20 AM
Finally will be dragging the 53500 Jacobsen into the garage and get to working on it.  I'll be swapping around engines, removing the rear PTO and redoing the wiring harness.  I don't think I'll be keeping it for too long expecially since i have the Ford 195 to do.  I live in a suburban area of Milwaukee so I don't have much room and right now.  I have 3 Allis Chalmers, 3 Simplicitys, 2 Fords, 2 Jakes, 1 Midland, 1 Cub, and a Deere.  Some stuff has to go lol
  • olcowhand said thank you
#36 jpswift1 OFFLINE
jpswift1
  • 789 Thanks
  • 615 posts
Posted January 14, 2018 - 02:54 AM
Any updates for us?  I have a Ford LGT195 that I picked up this Fall and I'm slowly putting it together with a Kohler Command CH23.
#37 MarksA-C OFFLINE
MarksA-C
  • 268 Thanks
  • 100 posts
Posted January 21, 2018 - 02:25 PM
I haven't done anything with this project and at this time I am going to be selling it.
Too much to do and my focus has shifted more towards my Allis Chalmers tractors.
Also tagged with one or more of these keywords: ford, lgt, 195, tractor
