Lost my GT18 ignition key
6 replies to this topic
#1 The Z Man OFFLINE
The Z Man
  • 7 Thanks
  • 9 posts
Posted December 13, 2015 - 11:21 PM
The ignition key for my GT18 fell out somewhere in the woods. i can still operate the ignition with a screwdriver, but it's obnoxious. Anyone know what kind of key I need as a replacement?
However, more than a replacement key, I'd really like to replace the switch with a keyless switch and start button. Anyone ever do anything like that?
Thanks.
  • chieffan said thank you
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted December 13, 2015 - 11:44 PM
Any mower key will fit it. And I saw three switches on ebay yesterday, for them I have a gt 18 also. It was under sears st I believe it's the same switch.
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted December 13, 2015 - 11:45 PM
Don't ever send 12v to your stator or you will fry it. Pay attention when your wiring a new one. And you can make a start button if you wire it right
#4 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted December 14, 2015 - 08:10 AM
That depends on what motor he has. Sears used the GT 18 badge in 78/79 on both the single Tecs and the Twins and they do not use the same switch, I found out the hard way.
What type of "keyless switch" are you looking at? You could use a toggle switch if you want to turn power on /off. you could also easily wire the solenoid/Starter through a push button, I would just make sure you have enough fail safes in the circuit ( fuses, relays, etc)
#5 chieffan ONLINE
  • 16390 Thanks
  • 9038 posts
Posted December 14, 2015 - 12:13 PM
I keep a nylon string on my key and around the steering column.  When those switches get old and wore the keys will fall out.  Not only on Gt's but the big machines also.
#6 The Z Man OFFLINE
The Z Man
  • 7 Thanks
  • 9 posts
Posted December 19, 2015 - 10:14 AM
Well, my wife found the key in the yard. Amazing.
But what I'd like to have is a large toggle switch for power on/off, and an adjacent button for start. Sequence would be: switch to on, push and hold button to engage starter, release button, operate, switch to off.
Maybe I'll spend a few hours starting at the wiring this winter and come up with something.
#7 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted December 19, 2015 - 12:01 PM
I like staying with a key switch as I can remove them at a show and some kid cannot start the tractor!
