Bobbin Winder For Speedy Sticher Sewing Awl
thread bobbin winder
4 replies to this topic
#1 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,668 Thanks
  • 2,858 posts
Posted December 13, 2015 - 07:46 PM
Not sure if anyone else uses The Speedy Stitcher or other brand of sewing awl but thought I would post how I made a bobbin winder from an old CD drive motor that mounts in a battery operated drill chuck and makes winding the steel bobbin easy.  The CD drive uses a magnetic clamp to lock the disc so that it turns when it is inserted in the drive.  The drive I had was old and had long since been replaced with a DVD drive so I disassembled the drive and removed the motor.  Once removed I took the shaft and hub out of the motor and now had a magnet that I could mount in a battery operated drill that had enough strength to hold the bobbin securely.  After wrapping a few winds of thread around the bobbin I mounted it on to the end of the magnetic hub that was chucked in the drill and holding the thread between my fingers to give it a little tension I quickly wound the thread on the bobbin.  Attached are pictures of the motor that I took apart, the bobbin from the Speedy Stitcher, the hub that I used from the motor and a short video of it winding the bobbin.  Hope this helps someone who is looking for an easy way to wind steel thread bobbins.
Edited by 29 Chev, December 13, 2015 - 08:09 PM.
  • DougT, Gtractor, Alc and 10 others have said thanks
#2 Little Irish Men OFFLINE
Little Irish Men
  • 825 Thanks
  • 470 posts
Posted December 13, 2015 - 10:04 PM
Wow very nice ,  what do they say the step mother of invention ? Any way....  I  am going to show the wife, she has a batter dill and she can do this .
Patrick.
  • chieffan said thank you
#3 chieffan ONLINE
  • 10,150 Thanks
  • 6,640 posts
Posted December 13, 2015 - 10:17 PM
Sure beats winding them by hand.  That is the way I usually do it but don't use many of them.
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted December 14, 2015 - 08:45 AM
Very innovative
#5 toppop52 ONLINE
toppop52
  • 5,267 Thanks
  • 4,764 posts
Posted December 14, 2015 - 10:04 AM
I have 3 heavy duty sewing machines from my years in the upholstery business, but those are handy little devils, and that's a neat idea!
