Shifting collar
16 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted December 13, 2015 - 02:03 PM
I still working on the small rider for my friend. The shifting collar is broke I can't find one and I can't find another gearbox. Can another one be machined ? If so doe anybody on machine parts he will pay he wants it finished for his kids.ImageUploadedByTapatalk1450033423.005350.jpg
  • Traill95 said thank you
#2 chieffan ONLINE
  • 10,179 Thanks
  • 6,651 posts
Posted December 13, 2015 - 02:39 PM
Not familiar with Cubs.  Is that collar supposed to be one piece?
  • bbuckler said thank you
#3 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted December 13, 2015 - 02:46 PM
This is off a montgomery ward rider and yes it was supposed to be one piece.
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 13, 2015 - 02:52 PM
Would something like these weld a hubs work?
http://www.agrisuppl...kets/c/1900075/
They can be found many places. Get one to fit the shaft and grind/cut to width.
Just a thought.
Brian
#5 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted December 13, 2015 - 03:01 PM
Just a thought.
Brian
I don't think it will. It has a piece the stick out a little the grab the gear.
#6 KennyP OFFLINE
  • 38,418 Thanks
  • 45,945 posts
Posted December 13, 2015 - 03:13 PM
That sure looks to be a real clean break in it. Is it cast? Possibly weld it back together?
  • Chris11 said thank you
#7 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted December 13, 2015 - 03:15 PM
I thought so to but it missing a small piece of it.
#8 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 13, 2015 - 03:16 PM
Hard to tell. It appears to stick out on the length (i.e. same direction as shaft) Some of these hubs are 1 1/2" or so long. Cut/remove what is not needed. The hub may not be 'hard' enough anyway. Just rambling thoughts.
Good luck.
#9 chieffan ONLINE
  • 10,179 Thanks
  • 6,651 posts
Posted December 13, 2015 - 03:37 PM
Weld it back together and build it up where the piece is missing.  Then work it down to the shape you need.  Is that doable?
#10 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted December 13, 2015 - 03:42 PM
. My sister call to tell him.
#11 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted December 13, 2015 - 05:23 PM
You could send it to me , and I would make you a new one.
  • Bruce Dorsi, KennyP, bbuckler and 1 other said thanks
#12 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted December 13, 2015 - 06:15 PM
I wouldn't charge you. Just trying to help you out.
  • Bruce Dorsi, bbuckler and CanadianHobbyFarmer have said thanks
#13 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted December 14, 2015 - 12:33 AM
I found a picture on google of the inside of the gearbox.
#14 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted December 14, 2015 - 04:02 AM
Brandon, is this just a forward / reverse gear box? Or high/ low box? Anyway, looks pretty special, that material might be able to be brazed, but not weldable, as its a powdered metal hardened.
I would send that part to Chris11 or myself asap to have a newone made. it woyld need to made from D2 material to stand up in a transmission .
#15 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted December 14, 2015 - 10:17 AM
Forward-Neutral-Reverse. I'm shipping it out today.
