* * * * * 1 votes
Cub Cadet 122 Project
27 replies to this topic
#1 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted December 13, 2015 - 01:37 PM
I have been working on my 122 the past few weeks, mainly the engine but am getting to the tractor now. I rebuilt the engine k301 into a new block and got a 2nd generation head in good condition for it. My old block had balancing gears but this new one doesnt (I hadn't planned to use them anyway). Currently the carb is apart and soaking in gas while I wait for the rebuild kit. I got a creeper gear recently in a trade with someone who lives near me and really likes cub cadets. The shifter lever spins around so that will need a new part and I will be removing the driveshaft soon and shortening it. I will upload some pictures soon.[attachment=178578:ImageUploadedByTapatalk1450031912.805604.jpg][attachment=178579:ImageUploadedByTapatalk1450031921.153055.jpg][attachment=178580:ImageUploadedByTapatalk1450031926.738674.jpg][attachment=178581:ImageUploadedByTapatalk1450031940.588270.jpg][attachment=178582:ImageUploadedByTapatalk1450031949.439273.jpg][attachment=178583:ImageUploadedByTapatalk1450031961.207154.jpg][attachment=178584:ImageUploadedByTapatalk1450031968.822382.jpg][attachment=178585:ImageUploadedByTapatalk1450031975.772631.jpg][attachment=178587:ImageUploadedByTapatalk1450031985.643837.jpg]
Edited by dlang94, December 13, 2015 - 01:57 PM.
  • BNK and Mark 149 J. have said thanks
#2 glgrumpy OFFLINE
  • 8,623 Thanks
  • 7,926 posts
Posted December 13, 2015 - 02:10 PM
Ummm! I see the links to pix, but no pix on my end. I'm not familiar with creeper gear, always thought built into gear case. Will be interesting to see what that is about. Is there a pedal or lever or what to make that work?
#3 KennyP ONLINE
  • 38,511 Thanks
  • 45,987 posts
Posted December 13, 2015 - 02:52 PM
That's all I'm seeing too, GL! Even tried to edit and nothing but links.
#4 IHCubGuy ONLINE
IHCubGuy
  • 1,539 Thanks
  • 1,602 posts
Posted December 13, 2015 - 04:48 PM
Cub Cadets use a separate direct/under drive speed box that bolts to the front of the regular transmission.  They were an option on all gear drive tractors.  Just has it's own shift lever to change the speed.
  • BNK said thank you
#5 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted December 13, 2015 - 06:02 PM
[attachment=178612:ImageUploadedByTapatalk1450047736.913567.jpg][attachment=178613:ImageUploadedByTapatalk1450047744.813295.jpg]
  • Traill95 said thank you
#6 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted December 13, 2015 - 06:03 PM
Dont know what I did wrong before, but thats the creeper.
#7 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted December 13, 2015 - 06:04 PM
[attachment=178614:ImageUploadedByTapatalk1450047803.549936.jpg][attachment=178615:ImageUploadedByTapatalk1450047811.819189.jpg][attachment=178616:ImageUploadedByTapatalk1450047820.286407.jpg][attachment=178617:ImageUploadedByTapatalk1450047833.605822.jpg][attachment=178618:ImageUploadedByTapatalk1450047845.588973.jpg][attachment=178619:ImageUploadedByTapatalk1450047853.072676.jpg][attachment=178620:ImageUploadedByTapatalk1450047860.989661.jpg]
And heres the rest of them
  • Traill95, Dieselcubmike, Oldford and 1 other said thanks
#8 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 862 Thanks
  • 719 posts
Posted December 13, 2015 - 10:26 PM
Nicelookin project. Keep hammerin' it'll be nice in no time.
  • dlang94 said thank you
#9 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted December 24, 2015 - 09:25 AM
Got some more done, the engine is almost back together and the carb is rebuilt just not on yet. I found a dipstick housing from a guy near me who I got a rear hitch from, just need to get a dipstick now.
[attachment=179702:IMG_2522.JPG]
I took the driveshaft out and got it all disassembled, the rolled pins didn't come out easily I sprayed them a few times with penetrating oil and they sat for day or two. I disconnected the transmission from the tractor and saw that the reduction input shaft had lots of wear on the rolled pin hole so I removed it and was able to find a used one for a reasonable price. I am hoping to get the bearing off the input shaft and reuse it since it is in good condition. When I took out the input shaft there was a metal cap it seems at the back of it that I just hammered out does anyone know if that's replaceable or if it was part of the rear bearing? I ordered a new driveshaft from Brian Miller and his cultivator spring kit. My throw out bearing may be reused too it seems in good condition. Also got the front PTO clutch apart and cleaned up a little bit.
[attachment=179704:IMG_2515.JPG][attachment=179705:IMG_2516.JPG][attachment=179706:IMG_2517.JPG][attachment=179707:IMG_2514.JPG][attachment=179708:IMG_2520.JPG][attachment=179711:IMG_2519.JPG][attachment=179710:IMG_2513.JPG]
Edited by dlang94, December 24, 2015 - 09:42 AM.
  • KennyP and BNK have said thanks
#10 KennyP ONLINE
  • 38,511 Thanks
  • 45,987 posts
Posted December 24, 2015 - 09:40 AM
Looks like you are progressing along fine here! Keep it up!
#11 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted January 05, 2016 - 11:19 PM
The parts all came in and got some more work done. The reduction shaft is in, got the creeper on, and the clutch spring is on the new shaft.
d3fc4c0f6325212edc7a81ae7803aa03.jpgf4848607a0a12e8e0bc1c588fb518c4c.jpg25adb5e8d91770a1546fda0769c641a8.jpg236982800dcd415eabe0e4c1f0d64a57.jpged5f36f29064ae2b05b3b94c0941e6e6.jpg7d468a8561b7f345e7681681692902f6.jpg
  • Alc, wvbuzzmaster and BNK have said thanks
#12 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted January 06, 2016 - 05:48 AM
Nice work! Never seen that technique with the use of clamps but good to see if you don't have access to a press. So you drilled a hole in your wood engine dollie for the shaft and start clamping...too cool! That third clamp no doubt was a must.
"Give me a bucket full of rusty IH stamp hardware and that will entertain me all day...and some"
  • KennyP, EricR and dlang94 have said thanks
#13 KennyP ONLINE
  • 38,511 Thanks
  • 45,987 posts
Posted January 06, 2016 - 06:01 AM
Look like that worked as planned!
  • BNK and dlang94 have said thanks
#14 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted January 06, 2016 - 11:16 AM
Looks like a lot of progress from what you started with :thumbs:
#15 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted January 08, 2016 - 10:12 AM
The clamp idea did work well for what it was, for the future I want to find what type of press I should have used and get one lol, I just wanted to do it with what I had. I was careful with that spring until I got the pin in so it didn't shoot the bearing at me. I made it a little further yesterday[attachment=181449:IMG_2569.JPG][attachment=181450:IMG_2568.JPG][attachment=181451:IMG_2571.JPG][attachment=181452:IMG_2572.JPG]
In the future I will make the breather valve come up higher but I flushed and filled the Creeper before reinstalling the transmission. I had to grind out the creeper lever slot wider.
