$100 front end loader
19 replies to this topic
#16 MH81 OFFLINE
Posted December 13, 2015 - 07:53 AM
It will make installing the hydraulic pump a lot more difficult.
:ditto:
But not impossible.
Make sure the pump you are trying to use will be OK in the vert position. Another consideration is will it have to be shaft down or can it be shaft up. With the low clearance of the GT6K, I'd bet the thing will need to be shaft down which will possibly put the seal (and retainers) under a little harsher use.
You may be able to run a belt thru a simple mule drive of some kind and then to the pump (now horizontal)
You would be using the electric clutch, so make sure the anti spin pin is good (no sense going thru all of it just to have the clutch junk out.
Also, while a decent unit, the GT6k isn't a super heavy frame. What you build under her will need to tie into the axel mounts at the rear and the pivot up front.
I would also investigate upgrading the front axel to 1" spindles and reinforcing the steering components, if possible.
  • Alc and Paulgo have said thanks
#17 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted December 20, 2015 - 09:49 PM
Now that's a steal in my book, around here loaders usually stay around 1000-1500.
#18 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted December 20, 2015 - 10:13 PM
What are you going to put on it? A bucket or forks or what?
#19 bill edler OFFLINE
bill edler
  • 20 Thanks
  • 31 posts
Posted January 22, 2016 - 04:41 AM
my  dad bought me a Johnson loader on a cub cadet in the early 70s it worked good until the wheels got  auger out at the bearings be careful to have heavy wheels on whatever you put loader on
#20 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted January 22, 2016 - 11:29 AM
I will give you $150 for it :smilewink:
