Variator question
7 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted December 11, 2015 - 08:52 PM
My 214 runs decent and all, but I've noticed when i pull the variator lever back to slow tractor down, it makes a slapping or knocking noise under frame? Other than that, when I move lever forward to go faster, it seems to be working fine.
  • JohnDeere110 said thank you
#2 JohnDeere110 OFFLINE
JohnDeere110
  • 215 Thanks
  • 91 posts
Posted December 11, 2015 - 09:08 PM
I didn't work on the variator on my dads 214 but from what I understand it is a lever that moves a pulley to adjust the speed. something might be loose so it jumps and makes a knocking sound. Im not an expert on these (yet :D ) but that would be my guess.
#3 Trav1s OFFLINE
Trav1s
  • 3,160 Thanks
  • 4,274 posts
Posted December 11, 2015 - 09:36 PM
I would guess the middle pulley in the variator is binding on the center shaft of the assembly or the tensioner spring is out of adjustment/needs replaced.
#4 lyall ONLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
have you put graphic powder on the variator, so the the center can slide back and forth?
have you checked the secondary belt idler and spring?
also check the secondary belt idler pivot bolt, sometimes the brushing gets worn and causes some problems.
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,776 Thanks
  • 9,918 posts
Posted December 11, 2015 - 09:38 PM
Hollowed out bore on that bolt is my guess, also.
  • lyall and coinman66 have said thanks
#6 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted December 11, 2015 - 10:08 PM
Got a schematic by chance so I can see what part you are referring to?
Thanks
#7 lyall ONLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted December 11, 2015 - 11:01 PM
the pivot bolt for the secondary belt idler - E, is behind the drive pulley - C
Edited by lyall, December 11, 2015 - 11:18 PM.
  • coinman66 said thank you
#8 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted December 12, 2015 - 10:31 AM
Thank u!
