Found a metal gas tank repair putty!
9 replies to this topic
#1 KennyP ONLINE
  • 38,385 Thanks
  • 45,933 posts
Posted December 10, 2015 - 12:00 PM
I was in Fastenal yesterday and saw a brochure on this product. It's made by Alvin Products and called Lab-Metal. I was looking at the brochure this morning and saw the Technical Data part. In the chemical resistance section, it says it is not affected by mild acids, gasoline, petroleum, petroleum solvents, oil or L.P. gas. It is a putty that you spread on like JBWeld. Comes in a pint can, but rather expensive, ~$30. But if it will work to fix pin holes in our tanks, I'd say it's worth it. Here's a link.
  • Bolens 1000, Bud, Gtractor and 12 others have said thanks
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted December 10, 2015 - 01:12 PM
I used this stuff. So far it seems to be holding. It even works on gasoline wet areas.
http://www.permatex....el-tank-repairs
  • Bud, Bruce Dorsi, KennyP and 1 other said thanks
#3 propane1 ONLINE
propane1
  • 8,724 Thanks
  • 4,131 posts
Posted December 10, 2015 - 02:30 PM
Is it as good or better than this stuff. I fixed an oil leak in a aluminum block once with this stuff. Block had pin holes in it. That was years ago, never leaked again. Noel
  • Bruce Dorsi said thank you
#4 chieffan OFFLINE
  • 10,164 Thanks
  • 6,642 posts
Posted December 10, 2015 - 02:45 PM
I still like the good old JB Weld Quick.  Or if not in a hurry straight JB Weld.  Just fixed a metal tank yesterday that had 4 tiny pin point seeps.  Put it on, remounted the tank and filled it up.  This morning dry as a bone where the leaks were.  Got to have the surface clean to work though.
  • Bolens 1000 and propane1 have said thanks
#5 Oliver 2-44 OFFLINE
Oliver 2-44
  • 52 Thanks
  • 42 posts
Posted December 10, 2015 - 03:42 PM
I've used the Alvin lab metal for some mower deck pinhole repairs and its help up. However be sure and check the expiration date on the bottom of the container. it truly does have a short shelf life. (and my Fastenal isn't the best about getting the old stuff off the shelf)
  • MH81 and Cat385B have said thanks
#6 KennyP ONLINE
  • 38,385 Thanks
  • 45,933 posts
Posted December 10, 2015 - 04:30 PM
I tried that on a gas tank and it did no good what-so-ever! I won't use it again!
  • propane1 said thank you
#7 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted December 10, 2015 - 05:05 PM
We used to use a product called liquid aluminum that was quite good in fixing gas tanks. The key to most putty and epoxy quick fixes is proper preparation and working environment, if the product is not cured in its optimum range and the surface is not prepared correctly the bond will most likely fail! The one thing to remember is they are never permanent, they may buy you time but most likely will fail much faster than a proper repair.
#8 KennyP ONLINE
  • 38,385 Thanks
  • 45,933 posts
Posted December 10, 2015 - 05:47 PM
The Lab-Metal has been used in auto body repairs since 1950, so I feel it is more viable as a repair than these newer 'solutions' that don't seem to work!
#9 dodge trucker OFFLINE
dodge trucker
  • 2,436 Thanks
  • 3,126 posts
Posted December 10, 2015 - 06:17 PM
I have had better luck sealing pinholes from the inside with Red Kote  or the POR 15 gas tank coating product.
  • HANKG and propane1 have said thanks
#10 HANKG OFFLINE
HANKG
  • 6,313 Thanks
  • 3,424 posts
Posted December 10, 2015 - 06:43 PM
I have had much success with this product it coats the entire inside of the tank automotive restorer's use it IMG_1269.JPG on their antique cars works great cost 15.00 when you are done sealing your tank pour the product back in to the can use it on your next leaking tank . I prep the tank with aquarium stone and acetone to clean it get rid of flaking rust empty tank rinse with water getting all the stone out pour in a little more acetone to help rid tank of water let dry. Perfect.
  • Bruce Dorsi, KennyP, karel and 2 others have said thanks
