Briggs & Stratton identification ?
17 replies to this topic
#1 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted December 10, 2015 - 08:15 AM
Can you tell me the year, model and HP of this Briggs & Stratton engine ?
143302%20is%20a%206hp%20Briggs_zpslesv06
  • KennyP and chieffan have said thanks
#2 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted December 10, 2015 - 08:20 AM
Asecc.com has all the info you need.
  • jdcrawler and chieffan have said thanks
#3 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted December 10, 2015 - 08:23 AM
That is one that falls into a gray area. The model is 143302 which is 14 cu in. It would be somewhere in the 5 HP range, give or take a little. I've never seen a date chart for those early six digit engines prior to the use of the code number. It would fall in the late 50s to early 60s range.
  • Bolens 1000, Gtractor, jdcrawler and 1 other said thanks
#4 cootertom OFFLINE
cootertom
  • 1,575 Thanks
  • 822 posts
Posted December 10, 2015 - 08:46 AM
Can't remember the numbers on mine but seems like that is the 1958 5 3/4 h.p. I'll have to check to be certain.
#5 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted December 10, 2015 - 08:49 AM
The 1962 and 1963 Bolens 600 tractors (and possibly 1964) used the B&S model 143302 engines.  ....They were advertised as 6hp.
  • Bolens 1000, jdcrawler, HANKG and 1 other said thanks
#6 cootertom OFFLINE
cootertom
  • 1,575 Thanks
  • 822 posts
Posted December 10, 2015 - 09:52 AM
142302 is the number for a 1958 5 3/4 horsepower.
  • jdcrawler said thank you
#7 jabelman OFFLINE
jabelman
  • 2,220 Thanks
  • 1,592 posts
Posted December 10, 2015 - 10:44 AM
this has been a topic before it's easier to date the tractor but roughly 58 to mid 60's . If I remember I think your panzer was a t70b from 1960
Edited by jabelman, December 10, 2015 - 10:47 AM.
#8 Talntedmrgreen ONLINE
  • 3,273 Thanks
  • 2,306 posts
Posted December 10, 2015 - 02:29 PM
The 143302 was widely used and difficult to date. It is a 5 3/4hp, as mentioned, and these guys have the range nailed. I have one I have not been able to get spark to...im the 2 1/2 years Ive owned it. Every ignition component is has been replaced =(
#9 MGP59DB ONLINE
MGP59DB
  • 1,674 Thanks
  • 763 posts
Posted December 10, 2015 - 05:50 PM
Yup - This is a 143302 - 5.75 HP that is on my '59' DB I know the 60' DB had a 143402 Damn near the same motor ,
@mrgreen - I know it is a longshot - but my uncle got a bad condenser - new, but bad - gave him fits . Try another one.
or if you are ready to give up on it - I need a back-up motor! :D
Edited by MGP59DB, December 10, 2015 - 06:02 PM.
#10 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted December 10, 2015 - 07:16 PM
I'm still trying to get a correct date on the Panzer tractor but I haven't had any luck with nailing it down with the tractor serial number yet so I thought I would try the engine.
About the only way you can set a date on the Bolens Ridemasters is by the serial number on the  Wisconsin engine.
Edited by jdcrawler, December 10, 2015 - 07:18 PM.
#11 HANKG ONLINE
HANKG
  • 6,301 Thanks
  • 3,420 posts
Posted December 10, 2015 - 07:28 PM
I have three of them 5 3/4 HP is correct but can't be dated with any accuracy.
Edited by HANKG, December 10, 2015 - 07:28 PM.
#12 jabelman OFFLINE
jabelman
  • 2,220 Thanks
  • 1,592 posts
Posted December 10, 2015 - 07:29 PM
you might want to contact dandy sales and ask Jim
also bill janitor? his Web site. someone had a partial spreadsheet with production dates and serial numbers. I would bet money yours is a 1960
#13 MGP59DB ONLINE
MGP59DB
  • 1,674 Thanks
  • 763 posts
Posted December 10, 2015 - 07:46 PM
I know my SN is 17690  -  now the 143402 on my uncles 60' is SN 51741  402 denotes a slightly different stroke or bearing and crank set- (I think)
I think it would be closer to a 61' but I am not sure.
#14 jabelman OFFLINE
jabelman
  • 2,220 Thanks
  • 1,592 posts
Posted December 10, 2015 - 08:01 PM
402 is for a mechanical governor not the airvane setup otherwise the engine is the same
Edited by jabelman, December 10, 2015 - 08:02 PM.
  • DougT said thank you
#15 MGP59DB ONLINE
MGP59DB
  • 1,674 Thanks
  • 763 posts
Posted December 11, 2015 - 06:56 PM
Are you sure ? - Because my 302 has/had a mechanical gov.
My Uncle used his 302 w/ Airvane as a template and made an airvane gov.  for this engine.
Works great too BTW :D
We had the book out and went thru the #s - I thought sure he said the #4 indicated something to do with a gear or crank difference.
Anyway - We have done 2 of these motors and I have to say they are a real Gem of a motor. The one on my machine runs great now .
Starts easy , I have no history on the tractor but it had to have sat for a very long time .
Back in those days they were changing things on the fly - My engine has openings on both front and back for oil check - his has only the front -on his 60' has it only on the back .
Hold on - My Uncle just called and is going to get his book for this.....
14= CID
3=design series related to cyl. construction
3=position of crank shaft and type of carb.
0= type of bearings -equipt with reduction gear or aux drive
2=type of starter = rewind
http://www.briggsand...tion System.pdf
