Back blade question?
12 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted December 09, 2015 - 01:52 PM
So im thinking about building a back blade to got behind my 300 jd. I was wondering if anyone has made their own an has a build thread or step by step build on one. i have a a home made snow plow that will be perfect for the build just wasnt sure if anyone had plans or pics of a build, or i was going to be the first on the forum.
#2 KennyP ONLINE
  • 40,222 Thanks
  • 46,806 posts
Posted December 09, 2015 - 02:22 PM
Is this going to be just a blade or a box blade?
#3 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted December 09, 2015 - 02:30 PM
a normal blade but im going to be able convert it to a box blade
#4 boyscout862 ONLINE
  • 13,446 Thanks
  • 9,392 posts
Posted December 09, 2015 - 02:36 PM
There have been several threads on this topic and there may be plans in the Manuals Section but I'm not sure. Please post picks of your progress so that we all may learn together. I've got a home made blade that came with a bunch of things I bought. I will try to get some picks of it for you. Good Luck, Rick
Try this as a starting point: http://gardentractor...ox-blade-plans/
If you want a sleeve hitch:  http://gardentractor...ve-hitch-plans/   and   http://gardentractor...ift-link-plans/    this will allow the use of commercial blades.
Edited by boyscout862, December 09, 2015 - 02:47 PM.
#5 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted December 09, 2015 - 02:53 PM
im going to be building a mount to hold it that looks like the tiller mount an use the hydro lift to raise an lower it
#6 KennyP ONLINE
  • 40,222 Thanks
  • 46,806 posts
Posted December 09, 2015 - 05:01 PM
Which tractor?
#7 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted December 09, 2015 - 05:24 PM
I'll be using my 300 jd
#8 KennyP ONLINE
  • 40,222 Thanks
  • 46,806 posts
Posted December 09, 2015 - 05:29 PM
Doh! Need to read the first post again! Got a pic of the tiller mounted to it?
#9 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
The cub will be for shows once I get it running again an tubes in the original front tires
#10 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted December 09, 2015 - 05:30 PM
I might or I'll go take a pick of the tiller mount
#11 glgrumpy ONLINE
  • 8,745 Thanks
  • 7,983 posts
Posted December 09, 2015 - 05:57 PM
Snow blade? Think on front is best and should be common. If you want box, then must be diff. I think it is easier to find an old blade, whether from front or rear off any good tractor and make mounts for that. Just using the curved blade and that would have the top edge formed and any braces, plus the wear bar for the bottom already on.  I have postings on here on a box blade I made from a rear blade already done by adding sides and top bar for the teeth. You can get teeth for it from Rural King or AGC (Agri-supply) catalog for less than $20 a piece and in many sizes. The mount for mine was just a 3pt. If you don't have that, have no idea where to start on a mount, but should be rigid, these take a lot of punishment.
  • Bmerf and michael.kitko have said thanks
#12 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted December 09, 2015 - 06:46 PM
I have a front snow plow/ dirt blade I'd like a back blade on the 300
#13 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted December 09, 2015 - 06:49 PM
Here's the mount set up on my tilleruploadfromtaptalk1449704903573.jpg uploadfromtaptalk1449704924380.jpg
