Mini farm implements
21 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,677 Thanks
  • 1,521 posts
Posted December 08, 2015 - 11:52 AM
The idea of it is cool. Been thinking about a mini chisel plow using shanks from a Ford Dearborn cultivator or something similar. Having 5 shanks arranged with this pattern '.'.' What kind of power should I need? I would like to get it built for a plowing match that is going on next year. I have a Moto mower 6020 to pull it and maybe a Massey 14. Any suggestions on design? Materials?
  • limebuzz, holdenboy1960, chieffan and 1 other said thanks
#2 backwoods OFFLINE
backwoods
  • 2,629 Thanks
  • 2,818 posts
Posted December 08, 2015 - 12:16 PM
I like the sounds of it how to you plan on raising or lowering it? As far as a design i would look at full size implements take a ton of pictures get measurements an build to the scale of your gt, also check around on the internet an see if anyone else has built any an see if they will share some info on their building expierences. That is the best info i can give you right now if i think of something else that will help you ill add it later.
  • chieffan said thank you
#3 Greasy6020 ONLINE
Greasy6020
  • 1,677 Thanks
  • 1,521 posts
Posted December 08, 2015 - 12:41 PM
Probably minion lift😉
No... I'll use some kind of system like the brinly dethatcher I have. It would be neat for hydraulics but I'm not that advanced or have that much cash...
  • backwoods and chieffan have said thanks
#4 backwoods OFFLINE
backwoods
  • 2,629 Thanks
  • 2,818 posts
Posted December 08, 2015 - 12:57 PM
An idea i just had was you could have it on wheels like the york rake(stone rake) an use the wheels to adjust height an the amount of weight that is on the teeth
http://www.newhavenp...om/YorkTA1.html
  • Greasy6020 said thank you
#5 TAHOE OFFLINE
TAHOE
  • 8,333 Thanks
  • 5,815 posts
Posted December 08, 2015 - 01:48 PM
Sounds to me like you are shooting for something similar to the Sears cultivator.
  • boyscout862, holdenboy1960 and chieffan have said thanks
#6 chieffan ONLINE
  • 11,760 Thanks
  • 7,276 posts
Posted December 08, 2015 - 02:09 PM
Dito.  Or the Brinly or DB cultivators with the points in place of the sweeps.
#7 Greasy6020 ONLINE
Greasy6020
  • 1,677 Thanks
  • 1,521 posts
Posted December 08, 2015 - 02:39 PM
I was looking for something that would rip about 6" deep. Or just look cool at a plow day. Those Sears cultivators are close to what I'm trying to do
  • TAHOE and propane1 have said thanks
#8 shorty ONLINE
shorty
  • 5,915 Thanks
  • 5,450 posts
Posted December 08, 2015 - 05:09 PM
I use an old cultivator to rip up the garden in springtime. It seems to work decent for me. I think it is a Power King. With five shanks, I can get it down 6-8" with out trouble.
#9 propane1 ONLINE
propane1
  • 9,726 Thanks
  • 4,509 posts
Posted December 08, 2015 - 09:37 PM
Garden tractors and/or antique tractors at this plow day. ?? I was wondering what you were going to do with the attachment at the plow day. I take a set of disks for my garden tractor to our plow day and do some disking, for entertainment, when the plowing is done. Noel.
#10 limebuzz ONLINE
limebuzz
  • 1,074 Thanks
  • 1,020 posts
Posted December 08, 2015 - 10:14 PM
I've actually been thinking about building something like this too. I have hydraulics on mine,so I can tap into them. But you can pick up electric lifts from princess auto fairly cheap.
#11 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,602 posts
Posted December 09, 2015 - 01:14 PM
Hi I built a digger last winter for use behind my Power King it works pretty good if I limit it to 6 inches or so I can pull in in plowed ground more than that the PK spins and digs down the rear tires are loaded with washer fluid and has 60 lb wts on each wheel. I made it 60" wide here's some pics
  • olcowhand, limebuzz, MH81 and 6 others have said thanks
#12 Greasy6020 ONLINE
Greasy6020
  • 1,677 Thanks
  • 1,521 posts
Posted December 09, 2015 - 09:18 PM
No it's 90 percent big stuff. I want to start the small stuff section. There is a guy with a little simplicity with a cultivator and duals. I thought it was cool
#13 TAHOE OFFLINE
TAHOE
  • 8,333 Thanks
  • 5,815 posts
Posted December 10, 2015 - 08:30 AM
These are obviously made for show, but figured you might like to see them!
  • limebuzz, MH81, 1964Deere and 5 others have said thanks
#14 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted December 10, 2015 - 08:46 AM
Somebody in those pics had a LOT of time on there hands!
  • TAHOE said thank you
#15 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted December 10, 2015 - 08:47 AM
LOVE that 4 bottom plow
  • limebuzz and TAHOE have said thanks
