Well, after my mistake the other day causing a fire, I
29 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,740 Thanks
  • 4,516 posts
Posted December 07, 2015 - 11:05 AM
Have put up a fire extinguisher and hung many water squirt bottles up around the garage. All bottles are set on the mist setting. And will put up a few more as I collect more empties.
Of course, the fire extinguisher I already had. Took me a few minutes to find it. So it was no good to me that way.
Any body know what these triangles are for? My father had them in his garage, then I hung them in my garage. I know what they are for, just wondering if you guys know.
And thanks for all your comments the other day. I never told my family yet and may never. They might send me to the home. Hehe
After my experience, and I don't want to sound like a preacher, but take a few minutes and look at your shops, and see if your ready, in case of a fire. Can you improve upon what you have, and if any of you have any ideas, let me know. Thanks again. Noel
  • Gtractor, hamman, wvbuzzmaster and 7 others have said thanks
#2 chieffan ONLINE
  • 11,775 Thanks
  • 7,282 posts
Posted December 07, 2015 - 11:20 AM
I give up.  Christmas decorations ?
  • propane1 said thank you
#3 HDWildBill OFFLINE
  • 8,985 Thanks
Posted December 07, 2015 - 11:21 AM
Keep out the gremlins.
#4 tater195 ONLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted December 07, 2015 - 11:23 AM
...Squirrel gaurd for the "nuts" in the shop?
  • oldedeeres and propane1 have said thanks
#5 propane1 ONLINE
propane1
  • 9,740 Thanks
  • 4,516 posts
Posted December 07, 2015 - 11:44 AM
They bring you good luck in your place of work. Noel
  • 637Yeoman said thank you
#6 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted December 07, 2015 - 11:45 AM
Dunce cap?
#7 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,672 Thanks
  • 4,647 posts
Posted December 07, 2015 - 12:09 PM
Not quite sure where you have the extinguisher mounted, Might I recommend mounting next to the exit door. Thought being is if an explosion (battery) or fire, the first reaction is to run for the door (if inside) or run to the door (if Outside) either way the extinguisher can be readily available.
Second, it dosn't need to be straped down in a way to make it difficult to remove. Mine (actually two of them) one is just hung on a bracket, the other sits on the floor (just inside the door).
It should also be rated for the type of fire you would expect, Chemical most likely.
And last, get rid of the water, spritsing a gas, grease, or chemical fire with water will only make it worse.
my 2c
  • wvbuzzmaster, Eric, propane1 and 2 others have said thanks
#8 classic ONLINE
classic
  • 5,694 Thanks
  • 2,386 posts
Posted December 07, 2015 - 01:29 PM
Good to see you making it a safer place to work. Keep a covered metal garbage can for oily or greasy rags, cardboard, etc. in the shop. We all need to take the time to work safely.
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted December 07, 2015 - 03:23 PM
Extinguisher locators
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted December 07, 2015 - 03:33 PM
Old School stuff  designed for larger warehouses, dairy barns, etc.
  • Cvans and propane1 have said thanks
#11 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,315 Thanks
  • 10,291 posts
Posted December 07, 2015 - 05:51 PM
I bet those triangles catch some kind of bug.  Unless they are to locate fire extinguishers.
#12 glgrumpy ONLINE
  • 8,848 Thanks
  • 8,035 posts
Posted December 07, 2015 - 06:02 PM
No! No! those are just Props to hold up parts when spray painting. Set on floor or bench, and just the small end touches the part being painted and no flipping or extra handling. THAT would be MY use, heh! Realize you need more than two to do this, duh!
#13 KC9KAS OFFLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted December 07, 2015 - 06:34 PM
I was really hoping they weren't Carbon Tetrachloride extinguishers!
#14 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted December 07, 2015 - 06:57 PM
Like LarryLB said, water is not good for chemical or oil or grease fires. It can have shocking results on electrical fires as well. There is also a pretty good chance it could be frozen solid for the next couple of months as well unless you have your shop heated at all times. Keeping the extinguisher(s) near the doors is good advice. When I worked maintenance I always brought an extinguisher with me where ever I took the torches as a well as a helper to watch for fires while I was cutting.
Jim
#15 propane1 ONLINE
propane1
  • 9,740 Thanks
  • 4,516 posts
Posted December 07, 2015 - 07:03 PM
Heated shop, will water mist, not put fires out. Not using a stream of water. Noel
Thanks for the input.
