Ohh boy... This is getting serious
18 replies to this topic
#16 daytime dave OFFLINE
  • 4,620 Thanks
  • 6,434 posts
Posted December 07, 2015 - 09:37 AM
That looks like a decent GT for the money.  I hope it pulls all you want it to.
#17 SpeedySqueegee OFFLINE
SpeedySqueegee
  • 34 Thanks
  • 12 posts
Posted December 07, 2015 - 08:59 PM
Thank MolonLabe for the link to the manual. I found the side drive belt cover on e-bay and will try to get it. Got the tranny flush and refill on the agenda for tomorrow along with engine oil, gas tank cleaning, replace fule lines and clean carb. Then I will try for a start up.
#18 MolonLabe ONLINE
MolonLabe
    Rust Wrangler
  • 522 Thanks
  • 293 posts
Posted December 07, 2015 - 09:43 PM
Sounds like you are well on your way to getting the old girl back in service. If you're going to replace the fuel line you might as well pull the shut off valve out of the gas tank and clean the screen, just pull it straight down out of the grommet. When you run the new gas line make sure it stays above the fan gear for the steering otherwise it'll get pinched  between the gear and frame, learned that one the hard way. Lots of help on here if you need it, good luck!
#19 SpeedySqueegee OFFLINE
SpeedySqueegee
  • 34 Thanks
  • 12 posts
Posted December 12, 2015 - 04:48 PM
Okay I got it running!!! Still needs the drive belt cover. Beside that, I think it is ready to work.
  • MolonLabe and Paulgo have said thanks
