Ohh boy... This is getting serious
18 replies to this topic
#1 SpeedySqueegee OFFLINE
SpeedySqueegee
  • 34 Thanks
  • 12 posts
Posted December 06, 2015 - 07:17 PM
I just picked up a Wheel horse 310-8 found it on Craigslist. Owner said it was used last summer but mowed way to slow. Given to him by father in law. Gas was left in the tank. But engine and tranny oil is clean. Spark plug looks ok, some dry carbon. Drive belt, usable. Deck belt is worn out. Looks like the wiring will need some work. I will put tubes in front tires. I payed $250.00 I will get to go tinker with it after I get the kid to bed. Anyone else have one of these?
Edited by SpeedySqueegee, December 06, 2015 - 07:18 PM.
  • daytime dave, Traill95 and HANKG have said thanks
#2 SpeedySqueegee OFFLINE
SpeedySqueegee
  • 34 Thanks
  • 12 posts
Posted December 06, 2015 - 07:21 PM
Here is some pictures
  • daytime dave, Gtractor, Traill95 and 3 others have said thanks
#3 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted December 06, 2015 - 07:28 PM
I never but my parents did , they bought it new in the eighties I think . It was given to my nephew last year . Had a small rear discharge deck
#4 tater195 ONLINE
tater195
  • 2,078 Thanks
  • 1,379 posts
Posted December 06, 2015 - 07:37 PM
I know its not the same thing, but I had 2 417A's, probably the best tractors I ever had. Sorry I sold them. I still know where 1 is and have a good chance of getting it back when that guy is done with it.
  • chieffan said thank you
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,017 Thanks
  • 9,648 posts
Posted December 06, 2015 - 07:40 PM
It probably has a 38" deck. Does mowing too slow mean the deck is too small for the job or the tractor doesn't move fast enough? I think the price was fine if you can get it cleaned up and running. Now that you mention it. He's complaining about slow mowing and the deck belt is worn out. He may have been trying to mow tall grass too fast. That 8 horse Kohler is a fine engine. You can even moldboard plow with that outfit.
  • MH81, chieffan and Paulgo have said thanks
#6 tater195 ONLINE
tater195
  • 2,078 Thanks
  • 1,379 posts
Posted December 06, 2015 - 07:46 PM
It should be a 10hp, 8 speeds (6 fwd+2 rev). 5.5 mph top speed might be seen as a little slow, but in the normal range for a GT
#7 SpeedySqueegee OFFLINE
SpeedySqueegee
  • 34 Thanks
  • 12 posts
Posted December 06, 2015 - 07:58 PM
Ya, he was talking about slow forward motion. He had about eight to ten acers to mowe. So yes, this was not the tool for the job. But for me... I need to pull dirt and rocks up hill.
#8 tater195 ONLINE
tater195
  • 2,078 Thanks
  • 1,379 posts
Posted December 06, 2015 - 08:04 PM
Put a fresh drive belt on it and it will pull anything you can get a chain around.... and find or fab a belt guard before you burn a hole in your pants.
#9 case1man OFFLINE
case1man
  • 187 Thanks
  • 134 posts
Posted December 06, 2015 - 08:12 PM
I have a 520h same body style great mower plenty of power
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,017 Thanks
  • 9,648 posts
Posted December 06, 2015 - 09:35 PM
Yes, sorry I missed the belt guard. The factory guard has a guide in it that keeps the belt from flopping around when the clutch is off.
#11 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted December 06, 2015 - 10:37 PM
I like that style of WH
back when I was a teen, I had a vertical shaft WH this would have been early 80s.   I do not remember the model, it had a blown up tec on it, 7HP if I remember right/  I had gotten an 8 or 10HP VM series tec to replace it and had issues with the retrofit.  I gave up on it at the time because even back then I knew a vertical shaft lawn tractor was essentially "junk" and wanted something with a horiz. engine because those seemed like the ones that all the attachments were made for besides a deck...
  • Oldford and chieffan have said thanks
#12 KC9KAS OFFLINE
KC9KAS
  • 5,329 Thanks
  • 4,672 posts
Posted December 07, 2015 - 05:13 AM
Nice find.
I too noticed the belt guard was off. You need the guard on in order for the drive belt to stop spinning when you depress the clutch to shift. If you don't have the guard on, the gears will grind and it is almost impossible to shift gears
Edited by KC9KAS, December 07, 2015 - 06:27 PM.
#13 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 319 posts
Posted December 07, 2015 - 07:50 AM
Those are great tractors and should provide you many years of good service. Don't know how well it's been serviced but the first thing I do is drain the transmission and check for water, flush with diesel and refill. The drain plug is in the left rear of the transmission and requires a 1/4" allen wrench to remove. Looks like the shift plate is missing so take a look at the condition of the shift boot, that's where the water gets in. For the price you paid it's worth putting a few bucks into to fix it up.
Here is the manual
http://gardentractor...r_key=all&st=30
#14 chieffan ONLINE
  • 9,628 Thanks
  • 6,437 posts
Posted December 07, 2015 - 08:12 AM
Looks like a very workable machine to me.  A lot of those older decks were shallow and did not have capacity but did a nice job of mowing.  Seems like everything now days is speed - want to mow once ever 10 days at 20 mph and have it look like a golf course when done.  Will make a good work horse for you.
#15 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted December 07, 2015 - 08:25 AM
a good friend had one the same style not sure about the model but he used to clear driveways around my grandmas neighbor hood with it an then mow lawns an tille gardens in the spring an summer
