Wanted
Looking for aa 6hp briggs
7 replies to this topic
#1 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted December 06, 2015 - 12:34 PM
I'm looking for a 6hp Briggs vertical shaft for my allis b206. It's a 70s motor but any 6hp Briggs with a one once shaft diameter would maybe work. Am willing to pay for shipping.
#2 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted December 06, 2015 - 12:37 PM
146707. 1151-01. 7002261 is the serial number off the motor that is currently on there
  • Lauber1 said thank you
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 06, 2015 - 02:26 PM
thats about a 1968 motor. hard to find them sometimes as a lot of tractors used the 140xxx series aluminum engines.
#4 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted December 06, 2015 - 04:58 PM
Any suggestions on a viable replacement? Idc if its that year just something thats of same specs that would work in place of it
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted January 22, 2016 - 01:42 AM
I have a 140x, series if you don't mind aluminum , it has the magnetron. Conversion can make you a good deal... 40 dollars
#6 jabelman OFFLINE
jabelman
  • 2,223 Thanks
  • 1,594 posts
Posted January 22, 2016 - 06:03 AM
look at the briggs 800 series. I picked up a brand new one from Northern tool
  • HANKG said thank you
#7 ACmowerguy OFFLINE
ACmowerguy
  • 392 Thanks
  • 361 posts
Posted January 26, 2016 - 01:18 AM
I would think the best solution, would be a new shortblock. You can just swap over your carb, starter, flywheel etc. to a brand new engine and for less than rebuilding or replacing with a different model. I did some checking and luckily I located an older 1980's set of microfiche in my "archives" which contained the service short block replacement guide.  A direct replacement would be a B & S part  # 299780 short block.  It appears that at some point they superceded that up to an 8hp short-block 397816 but then you would have to get an 8hp cylinder head to match it as the 6hp is different. While that shortblock is NLA, you can add 299780 to your ebay saved searches and they will email you whenever one is listed.
Edited by ACmowerguy, January 26, 2016 - 01:19 AM.
#8 CraftsmanGT OFFLINE
CraftsmanGT
  • 224 Thanks
  • 266 posts
Posted March 09, 2016 - 02:46 PM
6-7-8hp Briggs all use the same block. No worries
