cheap power king
10 replies to this topic
#1 Tomwendt OFFLINE
Tomwendt
  • 132 Thanks
  • 147 posts
Posted December 05, 2015 - 06:25 PM
I'm picking up a power king tractor tomorrow and do not know anything about them.i know it has large rear tires ,24 i think full three point hitch,duel brake pedals and a 17 hp kohler twin.it has been sitting in a yard for quite a while and i finally caught him home today.he said the only thing wrong with it was the lower end of the shifter needed fixed,and the parts are there.its a newer model either plastic or fiberglass.when he said 50.00$ i figured i couldn't lose.any good,bad or uglys.thanks in advance.
  • Alc, KennyP and Bolens800uk have said thanks
#2 poncho62 OFFLINE
poncho62
  • 1,093 Thanks
  • 1,405 posts
Posted December 05, 2015 - 06:27 PM
You are right.....cant lose.......sounds like a heck of a deal
BTW....pics or it didnt happen
#3 Tomwendt OFFLINE
Tomwendt
  • 132 Thanks
  • 147 posts
Posted December 05, 2015 - 06:39 PM
getting it tomorrow morning.
#4 boyscout862 ONLINE
  • 11,424 Thanks
  • 8,456 posts
Posted December 05, 2015 - 08:30 PM
You have a great deal there. Check the Manuals Section for the info you may want. There was a thread a couple years ago that showed the repair of a PK shifter. Good Luck, Rick
#5 KennyP OFFLINE
  • 34,194 Thanks
  • 43,316 posts
Posted December 06, 2015 - 05:56 AM
That sounds like a great deal!
#6 glgrumpy ONLINE
  • 8,099 Thanks
  • 7,543 posts
Posted December 06, 2015 - 02:37 PM
Kt 17 might be junk. 4sds lots of trouble and clutch paks usually bad, leak from bad trans seal wrecks them. Money pit. Chassis is great. Money Pit! Note from the Darkside!
#7 glgrumpy ONLINE
  • 8,099 Thanks
  • 7,543 posts
Posted December 06, 2015 - 02:49 PM
You CAN LOSE! At least $50 to start.
#8 Tomwendt OFFLINE
Tomwendt
  • 132 Thanks
  • 147 posts
Posted December 06, 2015 - 04:47 PM
worse comes to worse ill part it out.the 3 point has to be worth that much i would think.
#9 abu507 OFFLINE
abu507
  • 9 Thanks
  • 29 posts
Posted December 13, 2015 - 02:40 PM
Email sent for pictures
#10 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 13, 2015 - 03:06 PM
For $50, you won't lose.  Yes, the engines are not the best and yes, the clutches in these tractors are horrible but, you may get lucky.  Parting out will surely get your money back if it comes to that.  There is an easy repair for the end of the shifter but I would gives odds that it's the clutch unfortunately.  I hope it works out well for you because they are nice tractors.  Good looking too.  Good luck.
#11 abu507 OFFLINE
abu507
  • 9 Thanks
  • 29 posts
Posted December 15, 2015 - 10:42 AM
Hi Tom still interested if you are send pics and location etc I'm off right now from work so hood timing
