Wifi booster
14 replies to this topic
#1 Jazz ONLINE
Jazz
  • 2,302 Thanks
  • 1,404 posts
Posted December 05, 2015 - 08:49 AM
I can't get a wifi signal in garage when garage doors are closed. The wife came home with this Netgear product yesterday. Today it will be returned for a full refund. Did not help and we already have the biggest modem our provider has. Not going to pay for a seperate service as they suggested. Signal just can't penetrate my fortress which is only 30' from house
Edited by Jazz, December 05, 2015 - 08:49 AM.
  • Traill95 said thank you
#2 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted December 05, 2015 - 09:11 AM
I never had much luck with the wifi extenders either. I went and got a product made by netgear called a powerline Ethernet switch kit. It will not give you wifi but works as a hard wire system. Runs throught the power lines in the house. I have had mine for three years and no problems. Internet in the shop works as good as in the house. Now if you are using a phone and can not hard wire like you can a laptop or desktop the this will not work.
  • Alc and Jazz have said thanks
#3 Traill95 OFFLINE
Traill95
    Traill95
  • 1,845 Thanks
  • 1,008 posts
Posted December 05, 2015 - 09:35 AM
I have the same problem, :(
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 05, 2015 - 10:12 AM
I've got a Netgear extender in the shop and works pretty well.  The extender is probably about 180 feet away from the modem.  When I first got it I experimented with putting it different places and I found the best place was in the shop by the window.
#5 tater195 OFFLINE
tater195
  • 2,077 Thanks
  • 1,379 posts
Posted December 05, 2015 - 10:16 AM
I have a repeater in my metal sided shop and it works fine most of the time. 100+ feet away from the main wifi. The one in the house is by a window on the back of the house and the repeater is in the window in the shop.
the only real problem I have on the TP-LINK repeater is it wants to do some kind of update/ refresh thing a few times a week and it gets screwed up. I have to do a factory restore and re configure it. It crapps up the wifi in the house when it goes screwy
Edited by tater195, December 05, 2015 - 10:18 AM.
#6 chieffan ONLINE
  • 9,577 Thanks
  • 6,413 posts
Posted December 05, 2015 - 12:51 PM
I checked with my computer guy on this same thing.  He said it has to be line of sight.  Absolutely no metal walls and through a window is best.   Don't need it for the shop but do for the wood shop which is about 80' away.  The main shop is a steel sided building and can go direct with my laptop to the house with good service.
#7 Traill95 OFFLINE
Traill95
    Traill95
  • 1,845 Thanks
  • 1,008 posts
Posted December 05, 2015 - 04:18 PM
I just ordered one of these after reading your post. Hopefully it will help get the internet to my workshop. :D
#8 Jazz ONLINE
Jazz
  • 2,302 Thanks
  • 1,404 posts
Posted December 05, 2015 - 04:41 PM
Wife called cable provider. They are coming Monday because I should have wifi service in garage :rocker2: ......that's good to know...
#9 daytime dave OFFLINE
  • 4,785 Thanks
  • 6,523 posts
Posted December 05, 2015 - 04:51 PM
I hope the cable provider helps you out.
I have used a range extender for several years with great success.  I keep it pretty much as chieffan describes.  Line of site with as little as possible in between.  I really like mine.
  • Trav1s said thank you
#10 Jazz ONLINE
Jazz
  • 2,302 Thanks
  • 1,404 posts
Posted December 10, 2015 - 04:37 AM
I went with a similar system. Works great. .
Edited by Jazz, December 10, 2015 - 04:42 AM.
#11 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted December 10, 2015 - 08:47 AM
I just ran a hard wire out of the providers modem box and put a another wifi box in another part of the house. Yea, we have to log on's but I already had the other wifi modem when we moved so it worked. I can get wifi down in my barn, it's 150' from the house.
#12 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 10, 2015 - 12:01 PM
There is a similar thread going on over on the PCLOS forum.  From what I understand from what they are saying is that if your electrical line is all on one group it will work very well but like in my case I have two groups, just below the power meter I have a box that has two breakers one for the house and one for the out buildings, so in that case it doesn't work as well.
  • Jazz said thank you
#13 tater195 OFFLINE
tater195
  • 2,077 Thanks
  • 1,379 posts
Posted December 10, 2015 - 12:14 PM
as long as you are not going thru a transformer, it should work. the grounds and hots should all be tied back to the same spot.
I have never really checked into these, not sure how well they would work on a GFI circuit
#14 Jazz ONLINE
Jazz
  • 2,302 Thanks
  • 1,404 posts
Posted December 11, 2015 - 04:15 PM
If you are in doubt if the system will work there is a 30 day return on these internet devices.
The system I use carries wifi over power lines. My garage panel is fed from a 60amp breaker in the house. When I built garage I ran all the hydro, telephone line and tv cable  underground to garage. As well I wired garage for the electric door opener I never bothered with,,also put separate circuit for the gas furnace I never bought. I just like to plan ahead
  • HDWildBill said thank you
#15 Traill95 OFFLINE
Traill95
    Traill95
  • 1,845 Thanks
  • 1,008 posts
Posted December 14, 2015 - 07:00 PM
I just put the same thing in my shop and it is working great.
