John Deere 214 rear wheel sloppy
6 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted December 01, 2015 - 02:56 PM
I've noticed the rear wheels are a little wobbly on the ol 214. Took rear wheel off to check bearing and it seemed ok? Slid hub back on and it was wobbly again. Do these hubs wear out? I think I'm missing a shim behind hub to maybe?
#2 lyall ONLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted December 01, 2015 - 03:35 PM
I would say that the hubs are worn.
There are several ways to stop the wobble.
In some posts they said to drill three holes on the flats of the hub and thread them for allen screws.
You can also make little shims or small nails to go between the splines on the axle.  Will work for a while.
Or hope you can find a replace hub/s.
If you do nothing they will worn more.
Be careful buying on ebay, you might be buying worn out ones.
Best you check them before you buy.
good luck
#3 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted December 01, 2015 - 03:39 PM
Yes and new ones are like $160 for a pair at John Deere!
#4 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted December 01, 2015 - 07:55 PM
Hubs are worn. how do those stay on pins or c clips?
  • coinman66 said thank you
#5 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted December 01, 2015 - 08:23 PM
Snap rings
#6 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted December 02, 2015 - 06:34 PM
oh ok. Nevr under stood why they used those.
#7 pidjones ONLINE
pidjones
  • 58 Thanks
  • 50 posts
Posted December 07, 2015 - 07:14 AM
Hubs are softer than splined shaft. They wear. Ebay usually has some for decent pricing. Don't wait like I did and have one strip completely - wheel stayed on but I had to tow it to the garage. Very easy to change out.
Edited by pidjones, December 07, 2015 - 07:15 AM.
